I’m planning an On3 shelf layout and need to know how much clearance I need for a Tortoise switch machine under the roadbed. I have not been able to find any specs on the tortoise and would appreciate it if someone could measure one they have.
Thanks,
Dennis
I measured the height of the Tortoise at just under 3 1/4 inches, which includes the height of the connector/soldering tabs that stick out of the end of the unit. You will need additional clearance if you mount a Hare or use a connector for wiring the Tortoise.
With a little work you can mount the Tortoise on its side and the clearance is 2 1/2 inches (as per the Tortoise bulletin).
You can find the Tortoise manual and bulletins at
http://www.tonystrains.com/technews/tortoise/index.htm
Thanks, that’s exactly what I was looking for.
Dennis
