Getting back into the hobby after a very long hiatus, 1984 was my last layout. I am impressed with the changes in layouts and benchwork over the years. My last layout was 4x8 and flat. My new one is going to be more adventurous.
I have looked at all the track plans in the database and have decided on a cookie cutter design. I am not able to figure out the plan detail to the benchwork with the different elevations and levels.
As I was unpacking my old cars and engines I found my first Atlas Plan Book. It actually has several plans that I like and more important it had benchwork detailed prints. I do not have to convert 48" 50" and so forth to L girders, though that was my first choice.
To make it as painless as possible I placed an order with the nice folks at Atlas for the entire components package. Track, bridges, turnouts and everything I need to lay on the new cookie cutter table top.
Now to my problem, they are out of stock on almost everything. Very resounding disappointment sigh! So who is the go to company for track and Accessories? Is HO track made to standards? Atlas and others 18" turn the same?
Have 8 grandchildren and I who are ready to start building!
15" is very tight and would preclude the use of all but the smallest of locos and cars. 18" is as tight as I’d go. With that you can still many small steamers and four axle diesels as well as forty to sixty foot freight cars.
This company has a lot listed as “next day” which means they have it on the shelves {I live very near them} They are usually well stocked on track…especially the code 83 {as I have listed all above}.
You can cancel your order maybe and order form those who have it in stock.
{Someones mentioned 15 “R curves, which may be in your track plans, and I would firmly mention that I would also avoid at all costs, any 15"r curves! the lowest I would go is 18” and I am looking to expand my small one to 22" and 24"-ers.}
You COULD get what you can, and build a small "practice layout while waiting for the trackwork for your larger one. Just a suggestion. Things have changed over the years since 1984
Lots of homework going on here. So many changes. I have a very large stack of books and have now moved to forums. I would not have not know about the 15 inch curves with coming here.
I gather that you are nto going to use 15Rs. i do hope you reconsider using 15Rs {not use them that is}, as I think you will be highly disappointed.
Yes, 15"r was a standard back in 1984, but now with bigger prototypes, and thusly bigger models, 18"r is the tightest I would go.
Some articulated steamers were designed to run on 18R. 6 axles locos {like SD-something locos} don’t like 15R at all.
I have a small 3.5 foot x 5.1foot HO scale layout that has an inner loop of 15R and an outer loop of 18 interconnected. I found the inner loop to be of little use! I COULD run my A-B set, and small steamers and 4 axle locos, but that’s about it.
I also like top run more mid-70s and some modern stuff…SO I have had to expand my layout and want to include 22R and 24R curves now. I WAS going with an 18R inner and expanding an outer 18R with spacers to allow it to continue outside the inner oval. BUT, I found I might as well expand to include 22R and 24R,so I changed my mind.
I suggest again you go up to the very tippy top gray colored tool bar to the “Shop” button, OR the middle top Black “shop” button and search for books for layout and design, which MAY help such as:
Fifteen inch radius is very tight. There are a few pieces of rolling stock that will stay on the track thru a fifteen inch curve but not very many. Eighteen inch is a much better deal. That’s the “train set radius” and all manufacturers go to a lot of trouble to insure that their equipment will run on eighteen inch radius so you can depend on everything except big steam and 80 foot cars to run well on it.
I would use the largest radius I could squeeze onto the benchwork, trains run better and look better on broad curves.
Larry, want some track cheap and there is plenty to be had? Think Brass! I know, I know many here will tell you it is junk and won’t stay clean.
I guess it was about 2 years ago I added some brass track to my good sizes HO scale layout. Guess what, the brass section does not get any dirtier than my N/S track and I am running DCC.
I picked up 20 brass turnouts for a whole $10.00 at a train show. Only thing I don’t like is the color, but if you paint your rails, no big deal.
