track buss install?
when installing the buss wires for the track does it matter where the booster wires make there connection? should the connection be in the middle of the buss or can it be at either end and not matter?
I have a digitrax system and the power buss directions recommend not having a continious loop so I placed the booster near where I have the beginning of the buss. It is also near the spot where the buss ends but is not connected end to end. The rail is also gapped at that spot too.
Many folks will tell you the middle, in order to get the least voltage drop at the end. If the bus is not extremely long, it really won’t make a big difference if you connect in the moddle or near an end.
My layout is 24’ long so in order to avoid a 50’ plus bus I put the booster in the middle. The busses are still upwards of 35’ in some places but as long as you use the correct gauge wire it is not a problem.
I’ve got about a 40’ buss and put it in the middle. I think you only have to worry about voltage drop when your talking 100’+
On a side note, I use 20 gauge solid wire form my feeders and I’m starting to regret it. Should have gone with stranded. I’ve had to fix two already where they broke.
I have a question regarding bus length. If the layout is 24 feet long, how do you arrive at a 50 foot bus? I thought that the bus length was from the booster to the end point. Is the correct method to double this distance?
My layout is dogbone shape bent in a U. Its footprint is 24’ x 15’ so my power is at the bottom of the U with Bus wires going out like many fingers up each side. I would say my longest bus is about 30’ or so. So far it works great.
Brent
Voltage drop is a product of length and wire size. Total bus length is out and back. So 40 feet one way is 80 feet of wire. There’s a drop at 1 foot that’s all but impossible to measure with our average meters. The drop increases as the length increases but can be reduced by a larger wire size. It can never be eliminated because wire and track is a resistor. What can’t be substantially increased is the size rail. Use a large enough bus and add as many feeders as possible. Bus size and length is the most important factor as the feeders and rail are parallel resistors and the total resistance in a parallel circuit will never be more than the resistor with the lowest value (the bus).
mfm, sounds like you know your electric theory. Im in my electrical phase in school right now. Im using 12ga wire for the buss and 20ga for the feeders. I’ve got a 80’ shelf layout.
Technically, no. The length is the length. But that is misleading because the current has to flow out through one wire and back in through the other. The actual wire (and electron path) length is twice the bus length plus twice the nearest feeder length. This ignores the fact that the rails also carry come current.
Karl
