anyone know a good place i can pick up one of those kits where you drill holes in the floor of a boxcar and have the cleaning pad hanging down
It seems like I once saw one of those boxcar types in the Walthers catalog . I once had one that was a caboose and didn’t care for it. I could never get enough pressure on the pad to really do any good. If I did get the right amount of pressure on the pad, then it would cause it to derail. So I just use an erasor to clean the track whenever it needs it. I clean the wheels of my engines with a Kadee electric wheel cleaner.
Yep, been there done that Georgaboy. My solution was to add some stick on weights to the car. Didn’t look pretty, but got the job done. Didn’t run it in a train, just used it for track cleaning only. Ken
I think they suggested a way of making these in MR a few months ago - they drilled holes in the base of a boxcar, glued a piece of hardboard to a couple of 6in nails, and poked the nails through the holes - there was no weight on the “cleaning pad” other than its own and the weight of the nails. I’ve not tried this as I use a Peco track cleaner block, but it would have the advantage of being able to remove the pad easily. I guess if you ran a car in every train fitted out like this it would help keep track clean, but I suspect fitting metal wheels to everything and cleaning the track manually would be more effective.
i bought a 4"x8" sheet of 1/4" masonite for my skyboard. with the leftover scraps i made pads to fit under ho cars that i drilled holes in the floors. then i epoxyied 1&1/4" roofing nails to the masonite pads. when the pads get dirty rubbing them on fine sandpaper cleans them off. a sheet of 1/4 masonite runs around $11. for my n scale layout i need 1/8 masonite. i should be able to make 10,000 pads. the pads do not need to be weighted to work right. they just slide on the rails. and they do work very well.
