track cleaning
I have a good amount of old O gauge and 027 track in good condition but it needs cleaning. What is the best way to clean this track?
welcome to the site! do you have a drill press? I have a small one in my basement I mount a wire wheel in. or a bench grinder, or even if you can mount a drill with a wire wheel. that’s the quickest. Or on my mounted track, I use a worn scotch brite pad. or fine sandpapr or emery cloth. If you have an understanding spouse, layout an old bed sheet, put a good movie on, and have at it in the living room. you’ll have the track cleaned in no time. I leave the dirt/rust on the sides of the track for that “weathered” look…
dirt and carbon buildup will fly off of the track with sandpaper. good luck.
Never use sandpaper. You might sand through the tin plate and then you have a conductivity and rust problem. The green meanie pads sold at grocery stores, not the ones with soap, do a great job of cleaning track. Then wipe it down with denatured alcohol. Another method is to go to the hobby shop and buy a “bright boy” track cleaning pad.
Roger
