Track feeder wire size for N scale Layout
I am building an N scale layout and used Atlas track feeder wire connectors that already had a wire soldered to the track connectors. My plan is to connect these drops to the track bus wire. My question is: I don’t know the wire size of the connector, I just know it is small. Will the small wire handle the 5amp booster I will be using?
As long as the feeders are short (in the neighborhood of a foot or less), small wire is fine.
Atlas uses 20 or 22 AWG wire and yes keep your feeders 18 inches or less. Just a thought…depending on how many feeders you will be using, it is much cheaper to make your own or solder directly to the track.
My .02 cents.
Thanks, Just wanted to be sure before I started soldering the connections to the bus.
Will it present a problem if 18 guage is used at other drops along with the Altas feeder connectors that is 20-22 guage?
Thanks
No problem at all, though 18 gauge is pretty big to solder to the rails!
