what size track nails for O27 track to nail down to ply wood table.
From experience, I would suggest you not use nails to attach track to just about anything. For example, if you are using the traditional O27 track with metal ties, one hard whack with the hammer can easily bend the tie and pull the track out of gage. Your next posting would then be titled, “Can’t figure out why train derails.”
Screws are the preferred method for attaching track to wood or foam. The length depends on tie thickness and if there is roadbed beneath the track. Generally speaking the screw would not need to be embedded into the wood more than 1/4 inch.
By the way, I use wood deck screws to attach my MTH Realtrax to two inch foam.
I totally agree with Buckeye … there’s no way to regulate the pressure on the track with nails … plus you may end up with humpty bumps in your track … uneven heights . Who knows you may want to move some also … how would one get nails back out safely without ruining or breakng your track . [#oops]
I use #4 flat head wood screws with Gargraves track.
They come in 1/2" & 3/4" long. Also in pan head.
Use the 3/4" if you have road bed.
Pre-drill for easy install!
I use screws for securing 031 profile tubular track, however I’ve used small flathead brads (maybe #19 or #18 1 1/4"? don’t remember) to secure Gargraves track with wood ties over cork roadbed.
I used a small tack hammer to start the nail, while above the track surface, then used a nail set to finish driving. This nearly eliminates the likelyhood of hitting the track. …Haven’t tried removal, but should be possible to pry up via the tie.
I use half-inch number-4 sheet-metal screws to attach O27 tubular track directly to plywood. I drill a 3/32-inch hole all the way through my half-inch plywood first.
I use Grip Rite Trim Head Square Drive #6 screws. They have a good track bolt “look” about them, and you can easily adjust the amount of pressure.
For all the above reasons NO NAILS. And you only need enough screws to keep the track in place. A screw in every section is not needed.
