Several people have commented on how nice my track looks. So here’s a run down on my process. I hand paint my track with a 1/8" round brush, using Polly Scale paints. Normally, I work back to front and right to left (I’m a lefty) to avoid dragging my hand over freshly painted track. For simplicity, I use the same color for the rails and ties. #414258 DRGW Freight Car Red for yard and industrial tracks and #414293 Zinc Chromate Primer for the mains.
Newly laid track for my engine service facility.
Painting the outside of the far rail. Most times there is enough slop from painting the rail to take care of painting the outside ties as well. If you want more color, you can go back over the outside ties.
Paint the inside of the far rail.
I keep a piece of paper towel handy to immediately clean up any paint the gets on the railhead. Although, often I use my bare finger. So by the end, they’re all rust colored. [:O]
Paint the inside of the near rail.
Randomly wipe the brush side to side across the inside ties. Don’t worry too much about hitting every part of each tie. This gives each tie a slightly different look.
Finally, paint the outside of the near rail. Again, touch up the outside ties if desired.
And the finished engine terminal. I added some Engine Black over the still wet Freight Car Red&
