Track Plan
KK, you might find this a little tedious to operate. Since the tail tracks are shorter than the spurs or yard tracks they serve, you’ll have lots of repetitive moves. Many folks find that a pain after a while.
But more concerning, there is no runaround, so the engine cannot move to the other side of the cars. Unless you use two engines, there’s no way to move a car from the spurs at upper left to the yard tracks at the lower right. All the plans I posted had a runaround track. If you don’t know what constitutes a runaround or why one is important, a little more study might be helpful before you finalize your design.
Regards,
Byron
You know Byron, this has come up so often lately, that I think I’m going to write an article and show a couple diagrams demonstrating what a runaround is and why its important. I’ll keep you posted.
[/quote]
[/quote]
Great idea Chip [:)]
well thats exactly the kind of stuff im looking for, helps alot. this is a basic design, and i can improve on it. so thanks for the tips, because this is a learning experience for me.
Does this help?
( I did these a while back and saved them. They use a double track main, but you get the idea. ) Click to enlarge
This blocks the main…
This will work…
This is better…
Now we’re cookin’ with gas!..
This sure does help me - I am trying to plan a new layout. Thanks.
Alan,
Glad it helped!
What is a runaround? Click the link and find out.
http://www.chipengelmann.com/Trains/beginner/runaround.html
That’s good Chip!
Better then mine!
Only because I made them specifically to make a point. Yours were handier.
well i read up on the yards section of the Layout Design Primer, and i think i get the basic idea, but i find it hard to understand without some kind of example or illustration…
where in this case would be the best place to put a runaround? two turnouts facing eachother on two of the yard tracks?
the LDSIG describes an A/D track to., and from what i understand, its a track where the switching crew put all the cars theyve pulled from the yard track, hook up a mainline loco, and go, right? what i dont understand is where is this track supposed to be located? is it one of the body tracks?
since this is a “port scene”, im assuming the way things would work is there would be cars stored on the top three or four body tracks, and when a shipment comes in, cars are moved into a consist on the lower one or two tracks, loaded, and then hooked up to mainline power and taken wherever they need to go.
i have alot of questions about this. the LDSIG helped alot, but like i said, id need to see a diagram or something to explain where everything goes.
KK, where did you end up with your plan?
