What are the factors and tradeoffs involved in selecting track size for a layout? Assuming a person is starting from scratch. As a longtime reader of MRR I notice most layouts trend toward larger sized rail and many that use lighter rail–Code 70 or 83–on visible sections revert to Code 100 on hidden staging areas.
Is it a question of cost? Are special turnouts and other track only available in certain size rail? Do trains run better on larger sized track?
Being a fan of the “track is a model” mindset I would love to do an HO layout in code 70 mainline and code 55 for sidings. What sort of obstacles does one run into going that route?
It is all those things. Code 100 was the standard, and widely available, and is easiest to use due to its true dimensions. It offers the least problems with flanges of various sizes that some might still want/have to use due to heritage units, inherited and gifted units, and the like.
If your aim is close approximation to scale, and to realism, IOW fidelity, then you should probably seek to acquire the slighter/smaller codes of rails. Just as the thinner tires and smaller flanges impart realism, especially with small and non-glad hand couplers and with finer and more numerous detailing on rolling stock, the smaller rail stock looks more like the real thing. However, it sometimes takes more skill or more careful handling as it is less robust.
I built the original section of my railroad with Code 100 track, because I was familiar and comfortable with it. When I moved on to the next section, I transitioned to Code 83. I like the Code 83 better because the ties are thinner and the track just looks more realistic.
Code 83 is a bit more costly than Code 100. All the new track is Code 83, even for staging, in case I wanted to change the layout and I need more track.
I did have some old European engines and rolling stick with pizza cutter wheels that rattled on the Code 83 ties. I also had some old Tyco cars that did that, but a planned replacement of all my plastic wheelsets fixed that.
This is purely my take on the matter, much like yours.
I think those that use Code 100 in hidden areas is primarily cost There is also some on operational factors, thinking of cookie cutter wheels were larger flanges may hit and ride up on frogs of smaller code turnouts. Size of turnouts is certainly a factor, whatever code track you are using.
I have not heard much about trains running better (or worse) on various code track other than the frog bumping, and that can usually be corrected with different wheelsets.
Since you are of the “track is a model” mindset and if cost is not a factor to you, go for it. I have never knowingly seen a layout with mixed track sized to fill the “track is a model” mindset, but then I’ve visited very few perminant layouts, mostly ones at shows.
I’m waiting for me to get into carpenter mode and get a shelf in my new room, but will be using all Code 100.
I do this mainly due to cost. I have 300’ feet of Atlas code 100 in the hidden staging areas. I use ME codes 83, 70 and 55 on the visible portions of the layout.
I did exactly what you describe on my upper deck - worked great. The only issue might be getting a full selection of turnout sizes and specialty track in code 70 and 55. If you are a fan of detailed track, I would bottom feed ME flex. They are up for sale but are still making track. They do make code 70 #6 turnouts but after that you are off to other brands for turnouts.
I have a completely different mindset when it comes to track. Function is what matters. I was perfectly happy with code 100 track on my last layout. When I started my current layout about 20 years ago, I switched to code 83 only because it seemed to be the new standard. I didn’t want to have different sized rail on different sections because that would require transition rail. When my trains are running, I don’t notice individual ties nor do I notice the height of the rail. It makes no difference to me. I’ve never been tempted to use lighter rail nor handlay rail. Commercial flex track and turnouts work just fine for me and in some industrial areas, I’ve made good use of sectional track. On sections of track I’ve laid recently, I have painted the rail but to me this is a minor detail and not something I really notice much at all.
We all have different things that are important to us when it comes to the choices we make. Track appearance has never been high on my list. As long as it functions well, that’s what’s important.
I use code 100 in hidden areas because I have scale miles of it (no exaggeration) from years (and layouts) past. I use code 83 for my heavy mainline, code 70 for branchlines and sidings off the mainline, and code 55 for sidings off the branchlines.
I do NOT use ME track unless there’s no alternative because I don’t like it - hard to curve smoothly. Others love it, but I use Atlas for the code 83, Peco for the code 70, and - ugh! - ME for the code 55 because they’re the only game in town.
I haven’t finished scenicing an area with code 55 track yet, so I don’t know if it’s worth the extra effort of connecting two different rails sizes together or not. Code 83 and 70, the difference is very visible.
Many years ago I built a module with a hand laid industrial section using code 40 stripped from old N scale track. With weeds, crummy ties, bumps and dips. The track looked great. But the bad part was the wheel width. Regular sized HO wheelsets looked awful. I also tried the proto 83 wheelsets but they also looked horribly huge. I have since scrapped that siding and rebuilt the module using code 83. Once it’s painted and ballasted it looks better with HO size wheels.
All my HO layouts were built with Atlas code 100, due to cost, availability, and my own built up inventory over the years. I did have a minor amount of Atlas code 83 on my last layout, and I certainly appreciated its improved realism.
That said, if I were building another layout today, I would still use Atlas code 100.
Why??? Well these days, cost is not a problem and I assume the supply is there.
But there is a factor that some of us “seniors” might be battling with, and that is the “harder to work with” challenge of the smaller rails.
Specifically, there is the soldering of feeders and joints, and even the placement of rolling stock upon the smaller rails, and so on.
For those of you with “young eyes” and “non-shaking hands”, this is all a moot point. But for those of us fighting these aging factors, it can be a huge deal.
The look of the smaller code is better down to code 70. Beyond that you lose the illusion unless you go scale wheels. Code 100 is much easier to put cars on the rails which can be why people use it in hidden areas, also it is more forgiving of bad trackwork. I started with code 70 and stayed and have no troubles with derailments, but sometime compermise is good and if I was going to start over I would proubly use code 83.
Code 100: Anything will run on it with no modifications. Too large for virtually any real railroad.
Code 83: Represents heavy rail in North America. Massive amount of products available. All newer designed products are made in code 83. Almost everything will run on it.
Code 70: Represents common rail used in North America up until recent mainlines. Older trains will bump the spikes as they roll along. Not much new product being offered.
Code 55: Represents industrial trackage and old time mainline. Flex track only and just from one manufacturer. RP25 wheels will clear the spike heads.
Code 40: Represents light industrial trackage. Must be handlaid by soldering to PC board ties. Even RP25 wheels will bump the spike heads.
Thank you everyone! That is very helpful. I’m returning to the hobby after a career and raising a family so I don’t have much legacy stuff but a lot to catch up on.
Unless you are going for a museum quality scale equivalent of the prototype. I wouldn’t worry too much about track codes and shy away from anything smaller than code 70. HO trucks, wheels, couplers, frogs, guard rails and more are not truly scale. Even the proto 87 wheels are too wide and have large flanges compared to a true scale wheel.
Proto87 wheels are exactly scaled from the prototype. Proto87 track usually uses ME or very similar rail in the appropriate height to represent the track being modeled. Flangeways are indeed to scale - which is even more obvious to most observers than the wheel width.
Normal NMRA RP25 HO wheels are called code 110 wheels. They are 0.110" wide, hence the designation. Code 110 wheels are nearly twice as wide as Proto87 wheels, and require much wider flangeways. There is also a set of standards for semi-scale wheels, known as Code 88 wheels. The Code 88 wheels will run well on NMRA standard track if flangeways are kept at the minimum dimension. But flangeways at the widest dimension, such as were used by Atlas (may still be), will have wheel drop in the longer frogs (higher frog #s). HOn3 generally uses Code 88 wheels, but there are some older code 110 wheels around.
The narrower wheels make a bigger visual difference on truss rod rolling stock and on small diameter driver locomotives. On more modern equipment models, the extra distance between the wheel and the unmodified truck frame may distract from the improved visual effect of the narrower wheel. This distance can be disconcerting using unmodified truck frames for Proto87 wheels.
Back to the OP’s question. Spiked code 40 rail will work with RP25 flanges in HO if very small spike heads are used. I have used the smallest size spikes from ME, and plan to try Proto87 spikes when I resume hand laying track. At one time ME (or its predecessor Kurtz-Kraft) made code 40 flex track for HO and HOn3. Or the code 40 rail can be glued or soldered instead of spiked (usually the case in N handlaid track).
Code 55 and code 70 rail work just fine with reasonably small spikes for anything except the AHM/Rivarossi pizza cutter flanges. I know, I handlaid code 70 rail in the mid 70s - code 83 rail was not ye
I totally agree Fred. A friend uses the the code 88 wheelsets, and to my eye, they do look disconcerting, especially because of the gap between the face of the wheels and the unprototypical-wide sideframes.
I’m guessing that those modelling in Proto 87 use true-to-scale-width trucks, too…but it must be a little more difficult to put a derailed car back on the track, especially if one has shaky hands and fat fingers.
I have used Code 100 for all my layouts for the most part (On my old layout, I did have a few sections of ME bridge track in Code 83.) as I mosty use sectional track. (I do use flex when a curve isn’t standard or the extra length is needed. I have a car shop that has flex track in the base due to the size.) As mentioned, it is heavy for prototype, but as I have some of the cookie-cutter Rivarossi engines (3 U-boats), it is needed. The rail can be weathered as needed to reduce the apparent height. As I reused the turnouts from my old layout and had built up a stock of Code 100 track, it made sense and cents to use and reuse it.
As someone has said before, it is your railroad and you can do with it as you please.
What little I know about Proto87 is that trucks must be equalized - this includes diesel trucks. No rigid one piece side frames on car trucks, which is entirely prototypical. So altering bolster lengths is probably not that big a deal to bring the sideframes in closer to the wheels on freight car trucks.
Although Proto87 interests me, reality is that it’s not for steam modelers unless you a machinist capable of making your own drivers. And I am not a machinist or a metal worker - my last name is Wright, not Smith.
As for re-railing, as I’ve gotten older and shakier and working in HOn3, I have really come to appreciate rerailing devices. A rerailer - which is very easy to make, even from cardboard - makes getting the wheels on the rails pretty trivial.
