Just how much realism do track spikes add to a line’s appearance? I model the NP in HO during the transition era, using Atlas code 83 tracks. Even with a layout measuring only 4’ x 6’ I’m leaning toward not bothering with all those micro-sized spikes.
[#welcome] to the forum. Your first few posts are delayed by moderators, but that will stop after a few posts. Hang in there, and do not lose faith!
I assume you mean the spikes that hold the ties in place on the layout. On Atlas track, these are generally driven through the center of the tie, so they ad zero realism. In reality the spikes are driven in against the rail flange. These spikes are already there on Atlas flex track.
Not exactly sure what the OP is asking about. Could be he asking if there’s any need for more spikes for appearance’s sake with flex track? Probably not.
If he’s wondering about using spikes to hold his flex in place, that’s exactly what I do. The spike is perfectly suitable for fastening down flex because it blends right in with the molded details. I usually put down a couple, one on each rail every 8" to 10". I usually apply to the outer rail, but you can also do inside the rail. Pick the right sized spikes and you can use the track over cork and have the spikeheads go into the wood just enough to hold well, without needing much effort to place them. My favorites for this are the Walthers-Shinohara 948-360 spikes.
Gentlemen, Ah, on closer inspection of both the Atlas snap track and flex track with its underside dimples, I see what you mean. I dont’ have enough flex track on the layout to justify adding a few spikes just for sake of appearance. I appreciate all your comments. Kerry
