Track Templates
Does anyone have some free track templates that I can print off and use? I need them to be in N scale.
Thanks for any help!
Brian
Brian,
I recommend you go to the Atlas website and download their free design software. It is called Atlas RTS 5.0. This program will permit you to design a layout in plan using Atlas N Scale components. Later, after you have it close, you may want to consider one of the comercial programs that will permit you to define the vertical geometry and use turnouts from other manufacturers. Even if you just want templates, you can print them off from the Atlas program at full size. Good Luck - Ed
Brian
Brian,
