Yes, you will have to cut rail with flextrack, but use some rail nippers (you can find them on Walthers.com) and/or a Dremel tool with a cutoff wheel. My favorite tool for cutting rail is a pair of sheet metal shears from the hardware store (they’re heavier duty than rail nippers and cut cleaner). You’ll also want some small files to clean up the cut ends.
In return for the above effort, you get trackwork that can flow however you want it and far fewer rail joints.
i used both to build my layout,snap track for a certain area and flextrack to basically fill in betwwen the lines.both are good,like anything else in life it’s a SITUATION DICTATES SCENARIO.
The only sectional track I used on my layout are the turnouts. Using flex has less joint which means less derailments. Just perfect the few rail joints, and there you go.
I use sectional track, on my brach and secondary lines which makes for a better depiction of old style “stick” rail with a minimum of effort. And I find for my purposes on those lines 22" Radius curbe handles the equipment just fine.
I use the flex track for my primary mainlines as it is a good depiction of modern “Ribbon” rail.
EZ- Track. I love the stuff to. It makes great lightweight layouts. And when I go in and Teach “The Geometry of Model Railroading” To my friends High School Math Class. Lightweight is a good thing.
I use a mixture of both, though I’ve been leaning towards flextrack–I’ll lay out a plan with snap track and when it is finalized I’ll take up the nails and lay flex. Most of my layout is straight, where the joints in snap-track are less of an issue, but my curves are so tight I can’t use pre-made track (unless I can score some of that coveted sub-12" Roco track or some Atlas 4-1/2" trolley track curves!) and have to use flextrack. Flextrack, of course, has more flexibility, and I’ve had to trim snap-track too…
EZ-Track would not be hard to ballast. Just get some of your choice brand of ballast and apply. However On the two display layouts I have made, I have not ballasted it becaseu the roadbed already has decent ballast detail. OH and if your running your big boys on EZ Track, you better get some of those 33 and 35 inch radius curves now avialable.
Handlaid all the way, just looks more realistic to me… but, again, thats just me. I have seen some great things with handlaid track, flextrack, and sectional track. Like someone said above, whatever the situation dictates.
Whilst I’d like the time to handlay track, I use flexitrack all the way, cos I just dont think sectional track curves look right. I like to ease into a curve, thus preventing a lot of derailments.
Oh guys. Please help me. I think that the click-clack of the wheels hitting the track joints is one of the things I am modeling. That is all lost with flex-trak. Am I wrong? I have spent a great deal of money, drilled hundreds of rail-joiners to run solder into joints where it won’t be seen, just to preserve the breaks in the track. Am I alone? It would be so much easier to finish my layout (around my entire basement) with flex-trak. But prototype railroads don’t have 100-yard jointless sections! Am I being radical? Someone please give me a reference point!
I thought about the same thing on the realistic clickity clack on the rails. My first layout had some flex track on it & what I did to get the realistic sound was use my dremel tool with a cutting disc. You have to take it slow & touch the rail lightly with the disc & try to make very small nicks in the rail to get the sound. Run a car across the nick until you are satisfied with the tone of the joint. Try not to make the nick too wide, It does take a while to do it right but the outcome can be very rewarding. I have screwed up some rail at times, But live & learn.
