Just thought I’d share, because I can’t do anything but laugh or I’d cry…
So it’s time for tracklaying to commence on the new layout. Yay!
After much advice and consideration, I decided to start with the logging line. It’s elevated and toward the rear of my shelves, so get it in place before I start the “in front” mainline, yards, etc.
The critical area of the logging line that will determine the rest is the “mountain” area where the logging camp as well as a coal mine sit. So we start there.
But, since one part of the logging line sits above the mainline (where it goes through a tunnel), I really had to lay that section of mainline first, so I wasn’t trying to do trackwork underneath a 10" high platform.
Fair enough. But one issue…
The critical placement piece for that section of mainline is a turnout where my staging yard enters. That turnout isn’t under the logging line, it’s a few feet away. But it’s placement is critical to the rest of the section that IS under the logging line.
So I have to start with that turnout, then the mainline under the logging line keyed off it, then the logging line.
Okay. Can do. But…
The entrance from staging must work around supports for the section of the logging line that goes through the staging area behind the backdrop. That section of the logging line must be carefully placed in relation to the spot where it pierces the backdrop to go back out front and become visible again.
So I have to start with one section of the logging line through staging, to position the turnout out of staging to lay the mainline under the logging line to lay that section of the logging line.
No big deal. We can do that. Except for one thing…
That cut through the backdrop for the logging line must be very precisely placed and is on a curve. This must be so because the logging line passes behind the passenger yard after it emerges, and a
