Traction Tires
Who makes a HO scale steam locomotive with traction tires? I am OK with new or used as long as it pulls. I have a 3.5 grade that unfortunately has to be.
Thanks
New or used? What scale? What radii? What type?
Even with traction tires, you’re going to be faced with other operational problems with that steep a grade.
You don’t indicate where you live, but here in the dry Arizona climate, traction tires are bad news because they dry rot and fall off too quick.
You might want to take a look at this web site. This stuff can be used on any locomotive.
http://www.bullfrogsnot.com/
Good luck!
I know that Mantua (prairie) and Rivarossi (hudson) have some on some models. Athearn as well but read the reviews first before purchasing… Any wheel arrangements in mind? Simon
I was thinking 2-8-0, 2-8-2, 2-8-4.
MTH have a few models, but their DCC decoders may not be compatible with your system.
I asked BLI about traction tires and they told me every one of their current production steamers is so equipped. I strongly dislike TTs and refuse to buy an engine with them. However I’ll give BLI a pass because they will provide a metal replacement for those of us who want one.
Same here. Slipping drivers can prevent a burned-out motor, and also provide an excuse to acquire more locomotives. [swg]
If your locomotive can’t handle a train on your grades, do as the real ones did: shorten the train, double the hill (move the train up the grade in two or more portions, then re-assemble it at the top), or add a helper or helpers.
Thank you everyone for your help.
Brian
There is a guy on ebay that has them all the time and they work great.
Try this guy: http://stores.ebay.com/llxlocomotives/
