Traffic Patterns
Hi. I have a question about something that happened on Train Simulator earlier today. I have played the activity titled Whitefish Freight Pull before and all of the trains that I pass along the way have been there. Today none of the trains showed up. I didn’t pass a single train through the whole activity. Does anyone have an explanation on what might have happened?
Thanks!
Willy
Thats pretty weird. Check the activity in the activity editor- replay it in that VCR tool. Check the time. It should start at 8:00. If you don’t see a mixed train with D9 on the point the moment you pull away from Essex something is not right.
Dig through your documents, you might have accidentally deleted some files.
Let me know how its going.
OK. I looked into the problem and found out that somehow the path for every train in the traffic pattern got deleted! So, I had to come up with a suitable path for each train so that the activity could run properly. Every thing has been fixed now. Thank You for the suggestions! [:)][:)]
Willy
Howdid it get deleted? Did you do something with the paths? How often do you go into your route files? I have never got that error!
Arondak; Any chance that you’re from the Adirondacks of up state NY???
I go into the files often, whether it is to make a new activity or make some changes on an activity. Maybe while I was messing around I accidentally deleted a path or 2.
That’s strange! I was thinking it would say,“Are you sur you whant to delete this path?” Has that not hapend?
,Arondak
I’m not from the Adirondacks! It’s the railroad of the FUTURE!
Yes it does say " are you sure you want to delete this path?" but sometimes wierd things happen. Or maybe I accidentally changed the paths that the other trains were travelling.
It’s odd but the problem is fixed and I’m happy with that.
Sometimes my computer crashes, and when it does I better hope everything is there when I turn it on again. My game freezes all the time, and its getting on my nerves. Good Luck.
Here is another question about traffic patterns. On the Cajon Pass Route High desert Rails Edition that was created by 3D- Train Stuff you go to the first activity in the list, I think it is called BNSF Barstow to Mojave or something like that. Then you start the activity and have a green signal. You keep going and the next signal starts green but turns yellow. By the time you get to it, it is at stop and proceed. I stop, ask permission to go through, get permission, continue ,and get hit head on by another train. Can anyone help me out on how to correct the error? I would appreciate any help.
Get the patches for it at www.3dtrainstuff.com. There were a lot of problems with the activities when it was first released. They incorrecly used the passing paths.
The problem is that I have version 1.6 and the most recent update is for versions 1.5 and lower. Any other suggestions would be appreciated.
I have v1.2
May I ask where you got v1.6?
I ordered it about 2 months ago right off their website. You are so lucky to have snow already! Here in Omaha we usually have to wait until at least mid-November for anything worth measuring.
Thanks!
Willy
Willy
