I am wondering what type of decoder would work for this loco. It is a bachman F7A Union Pacific that came with the pioneer Silver Series Train set. Pictures are on layout site in my signiture under Decoder?
I suggest you visit Digitrax’s website,they list I believe all their past and present produced decoders.However,depending on it’s design,your loco may not be an easy retrofit and may require some special care to do so.
Jon,
You can also e-mail Bachmann directly and ask their recommendation on a decoder for the F7. I’m guessing that since the locomotive came with a set, then it’s one of Bachmann’s “Standard” series locomotives. It’s worth getting their input.
As far as the this particular F7, I don’t know if if’s worth putting a decoder in it. For a little more, you can pick up an already decoder-installed Bachmann locomotive. No where near as nice as their Spectrum series locomotives but you don’t have to hassle with purchasing and installing a decoder yourself. Some decoders are easy to install. These probably will be a bit more work.
My experience with trying to put decoders into Bachmann locomotives that are not Spectrum and/or DCC ready is that you are going to need to disassemble the frame halves so you can get to the motor and isolate it. The big questiion I always ask myself: is this locomotive worth the cost of a decoder and the effort of disassembling it? My answer is usually, NO.
You might also try contacting Loy’s Toys. They are very helpful and might be able to offer you some guidance as well as sell you the decoder.
Jesse
I was kind of thinking it might not be worth puting a decoder in but I only have like two trains and the other one is an old steam which i thought would be hard to put a decoder in for the first try at it.
Jon, does the loco drive on all wheels or just one truck? I have one of the Bachmann Plus F7s (all wheel drive, flywheels, etc) which will definitely be getting a decoder when I can afford one as it looks a simple installation and the loco’s a great runner. On the Plus F7 you have to remove the piece of the pickup that presses against the frame - it’s basically a brass “hoop” that passes the current from the wheels to the frame. My plan would be to clip this off, and solder a fine, flexible wire to the pickup instead (as on the other side of the truck) - this would isolate the frame from the rails. A piece of electrical tape would also be used to isolate the motor from the frame (taking no chances here!). I would recommend a decoder with BEMF as these give amazing slow-speed control. The one thing to watch is the current draw, as I hear some Bachmann locos can be a bit “hungry” (not tested mine yet, as it’s a way down the “to do” list for DCC).
If it’s the version with a single power truck then you really do have to ask whether it’s worthwhile - Bachmann will sell you decoder-fitted FT A and B units in assorted schemes, they look pretty good models and are not much more expensive than a decoder. You could easily convert your existing loco into a dummy, then run it with an FT A and B to make an ABA set - would look pretty impressive!
yea its the two truck ran one. But also mine doesn’t run very well and it isn’t the roadname i will be modeling i am modeling the Rio Grande and its a Union Pacific.
