Train direction??
For those of you that have an around the walls layout like I do, which direction do your trains travel? Is there a “right” way/rule?? I ask this because I intended to have my trains go left to right, but the way things are looking, it would look better for them to go right to left. I know its sort of a silly question, but chime in and tell me which way your trains travel and why. Thanks.
Why wouldn’t they go both directions? The real ones do.
My layout is a linear around the walls affair - to the left is WEST, to the right is EAST. trains run in both directions.
My layout is double track, but even a single track line with a few passing sidings can support operations in both directions.
Sheldon
My trains go in both directions because that’s how trains run.
Car races and merry go rounds just travel in one direction.
I have a dual-track main around the walls, so it doesn’t really matter, except that I have the outside track as primarily counter-clockwise and the inside track clockwise, and have labelled them respectively northbound and southbound. If you have a single track mainline, run 'em however you want - there is certainly no “rule” about it.
Not the smartest question I’ve ever come up with.:frowning: I may have just had a senior moment. I am now a Grandpa, so I guess I’m eligible :slight_smile: I haven’t had a fully functional layout since I switched to DCC, and on my DC layout the trains went in one direction. I REALLY need to get track played and trains running.
It’s a left brain right brain thing. If you are more of a lefty you will generally run your trains in a counter clockwise direction, as this gives you a feeling of comfort and organization. An adventuresome type (right brained) will run them clockwise as it gives a feeling of challenge and makes them feel like they are off to conquer new frontiers.
I have traveled the world and have participated in what many would consider somewhat extreme activities, but when I am tired I like to just sit and watch them run in an anti clockwise direction, it relaxes me. When I am full of pi** and vinegar I run them the other way.
That’s very interesting, I’m left handed…
Look at your TIMETABLE. Nost railroads have an EAST and a WEST according to their timetables.
LION follows the practice of NYCT and has a NORTH and a SOUTH according to its timetable direction.
At the north end of the layout is 242nd Street, a two track/center island terminal with a double crossover switch at its south end. At the south end of the layout is the South Ferry Loop, a sing track, single platform station that turns southbound train into northbound trains by the secret legerdemain of the timetable.
The express trains also run north and south (each on its own loop, but you the viewer cannot see that this is so). So no matter where a train is on the layout it is either northbound or southbound and usually I have to look at the train and think twice before I can picture which way it is going according to the timetable.
Anyway, the information is right there in front of you on your timetable. If you have not made a timetable yet, once you do so you will find out which way your trains are going.
ROAR
Your prototype may give guidance whether you’re working with N/S or E/W. The Rio Grande gives me E/W to work with.
But this is a bigger issue than just model railroading, which are mapmaker’s conventions or rules of thumb. West is to the left, while East is to the right, presuming that a person is oriented at all. I’m constantly surprised at how many people are clueless about what’s E/W/N/S in conversation just here in the community, but I;m from out in the country, so…
Anyway, people will tend to follow that convention. N/S is somewhat different, although again there’s a tendency to see S as left and N as right.
Which doesn’t mean you need to, so long as your stations and other locations are clearly marked as E or W on the signage so people can refer to them to relieve any slight confusion. In my case, the way the trackplan and room worked out, I have E/W backward, as East if to the left, while West is to the right. It’s bothered me a little, but not as much as the other compromises needed to fix that in the original plan to do it the usual way.
I also have my East and West reversed. The bench on the left is suppose to be East of the Rockies, while the bench on the right is suppose to be West of the Rockies. In reality the bench on the left is on the West side of the room. Oh well at least the line through the Rockies is in between the two.
Now my brain hurts, I just can’t tell if it is the right side or the left side that’s hurting.[:|]
This works fine Brent if you are looking at it from the North as opposed to the stereotypical view with South on the bottom.
I hear the poles are getting closer to flipping again. I suppose all will be well then.[(-D]
I’m left-handed, but on the Yuba River Sub, if a train runs to the right out of the main depot of Deer Creek, it’s ascending to the summit of the Sierra Nevada, if it runs left, it’s heading downgrade to the Central Valley. At least in theory. However, my garage layout is laid out in a very large double-dog-bone, so thanks to a couple of horseshoe curves, my trains could be ascending or descending in almost ANY direction, LOL! For instance, Yuba Summit–the crest of the Sierra–should be to the east (right) of Deer Creek, however it has ended up actually being to the WEST (left) of Deer Creek, because that’s the only place I could fit it.
Yah, PLAN AHEAD, lol!
Tom [;)]
There are some rail routes that run, primarily, one way, with no other rails in plain sight. Think of two railways that merged, one with easier westbound grades and one which favors eastbound traffic. The new ‘double tracks’ could be in different valleys, with a tall, rocky ridge between. (That sort of happened with the N&W, VGN merger.)
As for clockwise or counterclockwise, there aren’t many routes that use that reference. Since the Tokyo loop line starts at a station a few stops south of Tokyo central the Up (toward Tokyo) trains run counterclockwise and the Down trains run clockwise - but the timetable says Up or Down, not clock direction.
In North America trains run (timetable) North/South or East/West. Our island-dwelling brethren across both oceans run Up (toward the capital city) or Down (away…) no matter how convoluted the intervening route. On my layout, Down trains have to drag themselves up a 2.5% grade to Tomikawa. The Up trains run downhill…
uhhhhh… I actually have no answer for this.
I have a double track main, so I usually have one train running counterclockwise on the outer loop and one clockwise on the inner loop. I run them this way to minimize trouble with the switches. I find that running trains so that they don’t have to go towards the point on the switch minimizes derailments.
This thread goes to show that even a rather silly question can evoke some interesting,entertaining and informative responses.
Well Sante Fe, like you, I had the idea of my train going opposite of what it does now, which would have been CCW (againsty the righty’lefty thing), CCW anyway in the main yard, station, scenery, action area, as my layout is some kind of a figure eight.
I ended up running them this way for two reasons- my locos pull the grades (3+%) better this way with long trains, though realistically it should have been the other way around as it is actually climbing out of the station on a steeper grade now, and, the train is in a (what I call) “primary” or optimal viewing postion coming OUT of tunnels, rather than going into them.
The route for my Shay runs either way.
Duane
Mention was made of the operation of prototype railways. The Southern, with headquarters in Washington, D.C., operated most trains south-north. But, there was the Carolina Special, a train that ran between Cincinnati and Charleston, S.C., with a North Carolina section that ran between Asheville and Goldsboro, N.C. Leaving Cincinnati, it was a southbound train–but leaving Harriman Jct., Tenn., it became an eastbound train, even though from Asheville to Charleston it actually was a southbound train with an even number (it did move farther east than south).
And, when you consider the righty-lefty thing, remember the Chicago & North Western, which operated left-handed when on more than one track (though the engineer was always on the right side of the locomotive).
I would say that you should run the trains the better way that suits your layout.
What is this? East is east, and west is west, and never the twain shall meet? … [:-^]
Actually, my layout is around the wall and double track. Trains go each way.
Happy Model Railroading! [swg]
