Does anyone know of a good website that has train heralds? So far the ones I’ve seen are images of various patches.
Thanks
Thanks
Try here
http://www.toltecimages.com/trains/heralds.html
Some are artwork…some are patches.
underworld
What end-use do you need one for? I went nuts trying to find one to use as a drumhead for the Broadway Limited. The pins/tie tacks were very nice, but too large. I found one net site selling them, and made a copy on heavy photo paper, which turned out printed in the exact size I needed. Joe
Tomar Ind. has an extensive line of drumheads, lit and unlit. They do not have a website but I believe their products are in the Walthers catalogue. www.walthers.com
I am putting up an elevated G Scale track, which is mounted on a ledger board. I wanted to decorate the lower portion of the ledger board with various train heralds. Thanks alot for the web site information it will work out well. (Printing the herald on some adhesive backed vinyl media I have.)
Did you find the ones you were looking for?
underworld[:D][:D][:D][:D][:D]
Oh Yeah, I downloaded 178 images. I’m going to print out a 6x6 of each, and then place them horizontally around the wall just below the track. I got the images from one of the sites you recommended. and the file size was perfect for the end size I want to end up with. Printed a contact sheet, maybe you might be able to see them.
Thanks a lot for your help.
