Consideration of the length of trains one plans to run is always a key element in designing a layout.
But how can you determine in advance how long your trains ought to be?
I stumbled across something this morning that may help.
I was sitting on the exercise bike this morning (yes, I was actually pedalling) and facing the layout on the opposite side of the room.
A consist of about 16 cars was parked on the mainline (hey, I’m in construction mode) and situated perpindicular to my axis of view.
I noticed that by looking straight ahead and not shifting my eyes or head to the left or right, it took about 14 cars to fill my field of vision. (These were HO 40’ and 50’ cars.)
So it seems to me that a good rule of thumb might be: Optimal train length for a given layout is the number of cars it takes to fill one’s field of vision when viewed from the farthest distance possible in the layout room.
Usually one will be much closer to the layout (for a tighter field of view) and with the added variable of scenery density, this should hopefully ensure adequate “feel” that there is a proper length train going by and not just a short-arsed model of a train.
it works , but does it stop working if you turn your head ?
perhaps it is better to have the layout divided by various view blocks into areas slightly longer than the longest train you run . brings us back to how long should that train be … maybe as long as your longest yard track ?
i really don’t know . just something to think about . it’s a very good question , and it has me scratching my head [:)]
I think you have certainly included the key element of “impression”, with that being dovetailed in with what the topography can show reasonably well from a number of angles, maybe only one.
I wanted to create the illusion of long coal drags, so I tow enough that the engine is in a second tunnel while the consist moves between it and the first tunnel with about a five car overage, plus caboose. Between the two close portals, the train seems endless. This way, when the whole emerges from the far side of the second tunnel and is turning around a sweeping horseshoe-type curve, I can still get some nice perspective and make it seem like a long train. For my purposes, anything longer than…why, what a coincidence…14 cars is longer than needed.
This image shows the train foreshortened, but the effect is pleasing, and the impression of length is right…for me.
My layout is a folded point to loop with a two-loop semi-exposed helix on one end and a furnace in the middle (it’s OK to laugh). I have to keep my trains short enough that the loco can run around it at the end of the run, so the limiting factor is a 5’ run around siding.
I think the toughest effect to create in model railroading is a 70-car unit train rumbling across the Wyoming prairie. Considering that an HO scale mile is over 60 feet, and that view encompasses a few miles of straight track and a train that is nearly a mile long, only a HUGE layout could come close to resembling it.
John Allen has been quoted as commenting that the overall effect is really what we’re after, not exact duplication in miniature. I think it’s a valid perspective.
So, getting back to the original post, I think you may be right - a good length is what fits in your field of vision - as long as you can fit it onto a siding when it meets another train.
My train length is limited by the tracks in my staging yard, which range from 15 to 19 cars. Visually, I try to break up my scenery so you don’t see the front and the back of the train at the same time, at least not often…
Looking at the train head on can give you a better illusion of a long train. I shot this recently on my layout…
Same location, a few weeks ago. The train is about 18 cars in each picture, but the number of diesels and the viewing angle trick the eye into thinking you’ve got 100 cars coming at you. Your theory proves correct!
Scenery definitely does make a difference. I personally like “dense” scenery – lots of hills, ravines, buildings, trees. I find the layering intriguing.
The key to creating the impression of a longer train is not being able to see both ends at the same time, I believe – just as one can’t with the prototype.
Between view blocks and my “fills-the-eye-at-greatest-distance” observation, I think it might be a workable solution.
To me 15 car train is too short and not very realistic. These days real railroads run long trains. My trains are usually at least 50-60 cars long. I usually use 3, sometimes 4 locomotives on the head-end to pull them.
I think it does because my observation was made from the greatest possible viewing distance in the layout room.
Under normal circumstances, one would be much closer to the layout/train, and thus even a prairie layout would have it’s own ocular “view blocks” so to speak. Without a lot of head swivelling anyway.
View blocks created by adding various types of scenery would heighten the long train effect.
I have always found peddler freights to be as neat as endless unit trains pounding past, both have their appeal. But, on my old layout, just to see if it was more fun, one day I hooked up a 40 car train, and to be honest, it didn’t add anything to the enjoyment.
I think the type of layout you have lends itself to what train length looks best- shorter for urban switching (i.e. point to point) and longer for loops where you can just sit back and enjoy a long train passing.
I’ve put a lot of thought into this as I am designing my layout. So far I’ve come to a series of rules to go by:
Unit Trains: Work on a ratio, a standard short unit coal train on the CP here in Milwaukee is pulled by a single AC or Evo unit. Usually there are around 80 hoppers, so when designing my unit coal train I worked on a 4:1 ratio, an 80 car train becomes a 20 instead.
General Freight: I’ve seen daily freights here and many other places I’ve railfaned and I’ve seen trains from 4 cars to 120+. Finally I decided to design my longest yard track to be only 18 cars long. However, I’m also considdering here how close towns will be spaced, and I’m thinking that the largest train on my layout should be the unit trains as well.
Passenger: Freight is actually secondary on my layout, the focus is actually a commuter line. I’ve studied how long prototypical consists are for commuter trains, and then realized that a platform for a 10 car train would be beyond workable. I ended up settling on four and five car standard commuter trains. Probably the only rule I’d go by with this one is to avoid ever using two or three car passenger trains unless that is exactly the number you want the viewer to see. Humans naturally pick up on groupings of two and three.
My prototype was running 20 car freights and <7 car passenger consists up and down the 2.5% grade in 1964. That’s 20 4-wheel cars, not 20 100-tonners or humonguboxes. The passenger cars were all 20 meters long.
I also noticed that there were shorter freights of up to 12 cars, pulled by lighter locos. These turned out to be local switching turns.
Fast forward 40 years, to the design phase of the currently under construction garage filler. A road engine plus 20 typical cars is under eight feet long. A 12 car local with a smaller loco is under five feet long. Hence, one staging yard is set up for eight foot trains, the other is set up for five foot trains. So be it.
my model railroad has 11 m passing / storage yards approx 35 foot long… i like to run long trains ( modern ) however when showing off my trains i run approx a dozen cars this is because i D O N T want any thing to go wrong i once ran a 100 + car train and it went 3 trips around before " disaster " my railroad is divided by view blocks only half a long train is visable ( 25 - 30 cars )… ps D C C helps with long running trains better control, peter
By the way, Tony Koester discusses train length in the 2008 Model Railroad Planning.
The idea is that you need to determine train length first, and then plan your layout (and staging) accordingly.
My longest staging track is way too short. Splitting my train can give me 20-25 cars in N, after which my door layout starts to look like a carnival train ride.
I’m thinking for “the big one” some day 25 boxcars or 30 hoppers is ideal plus 2-3 locos and a cabin. TK mentions the effect of scale also, i.e., a 20 car train in N scale looks shorter than the same 20 car train in HO.
That’s a pretty good length for a 1950’s-60’s era train. I model early- to mid-1990’s so most of my cars are longer than 50ft, lots of auto racks and 86ft hi-cubes; this means I can only run a max of 10-12 cars plus 2 locos for that type of train. I compensate by having limited-sight viewing areas, and running the trains extra-slow.
