Started out as Tru-Scale Models freight and building kit line…
Then became Silver-Streak Models Plastic Line…
On to becoming Train Master of San Diego…
Next for the longest run as Train Miniature of La Mesa…
Moving to Illinois, they became Train Miniature of Illinois…
Ending as Wm. K. Walthers Company of Milwaukee…
The Walthers 50’0" Airslide kit tooling was cut by TMofI, before they went under…
TMofI did the tooling for a least one Weaver Models O Scale Car Kit…
TM announced in later 1971 that both a powered and dummy Fairbanks Morse H-16-44 would be released in 1972… Was released by Willie K. some years later
TM 50’0" 1 1/2 XM was annnounced for release in May 1972…Did the tooling ever exist???
TM for the years that the glass window packaging was used had a 36 single dome tank car drawing…Tooling was cut…but never released…until Willie K. did some years later…
TM did indeed cut tooling and did produce a very limited number of the 42’0" drop bottom gondola… A new product announcement did appear in MR, with a photograph of the undec model…
TMofI had injected molded kit boxes, that were not tall enough to contain assembled high car kits…
Then switched to cheap carboard boxes, the paper thickness being the rolls for paper towels…
Can’t forget those trucks with actual springing…sounds good, but the scaled down physics didn’t quite work so well as the theory. Some expressed frustration with getting the springs in. I just found they tended to bind and not follow track as well as the design promised. Still run a few for nostaligic reasons.
I found that cleaning-up the castings, especially the portion of the bolster ends which fitted into the sideframes and the matching portion of the sideframes, really helped those trucks to work well. I moved some of the TM sprung trucks to my Athearn 2-bay hoppers and found that the loaded cars, at 8oz., actual compressed the springs somewhat, allowing the sideframes to pivot slightly about the bolster when passing through turnouts.
Thank you for doing this. An interesting chronology, some of which I was unaware of, and which made me go to the shelves to see what I had.
One thing I note: one plastic box is labeled Train Miniature of Illinois LTD. The other is labeled Train Miniature LTD of Illinois. So it seems there was at least one other slight variation in the name apart from your list.
One other general comment. As I recall, it was not easy to find a replacement metal wheelset that would drop into the TM/TMofI trucks and roll well. Often I just replaced the entire truck. The truck tuner tool solved the problem but by that time TM had long since been sold to WKW. Another peculiarity – the Train Miniature plastic wheels in turn were just about the only replacement 33" wheel with RP-25 contour that could drop in and roll well in the trucks that came with the AHM freight cars on the 1960s – of which I had so many that after removing all the plastic wheels from my TM cars, I actually purchased more TM plastic wheels for my AHM cars. There cannot have been many of us who actually purchased TM wheelsets because they were not really very good. But the AHM wheels were severely undersized and had huge flanges, and again this was pre truck tuner. Fortunately I replaced the wheels BEFORE I body mounted the couplers, so there was at least a chance of getting the height correct.
So here is what I find on the Nelson shelves.
Train Miniature (La Mesa CA) 8093, Ahnapee & Western 40’ double sheathed reefer. Cardstock box but a glassine or plastic window for much of the cover. The instructions (which refer to a 2300 series) call the firm “Train Miniature Products.” Yet another name? I bought the car used, and someone had spilled solvent or lacquer on the roof and this was a difficult salvage job. The ice bunker hatches are not, I think, factory originals because those had literally melted into goop. &nb
Most of this is familiar to me, but I have only a vague recollection of an FM H-16-44. I thought it was announced but never released, and I was surprised by the suggestion that Walthers released it later. I find that a bit hard to believe. However, I was always under the impression that the Walthers FA-1 and FA-2 were based on TM tooling.
Yes, the Walthers FA is the TM body shell, with a much improved drive. The run very well on DC and since everything is nicely wired (no chassis power), they aren’t hard to put a DCC decoder in. They just need the application of a disel dress-up kit to get free standing grabs, ladders, and lift rings, and they look fine.
When Train Miniature brought the FA/FB1 years back I bought a few .Unfortunately the drive was just OK. My solution was to use theHobbytown FA drive chassis. This was a pretty good combination.I added some details.On the FA the number boards did not look that good so I used some Athearn PA1 number boards shave down which gave a better Alco look. It wasn’t untill the Proto FAs and E&R FAs came out the I noticed how far off the TM/Walthers FA nose is . If you place the TM side by side with the Proto and E&R you can easily see the difference . Both the top of the nose and rounded front of the TM are way off. Place the TM unit next to an EMD F7 shell and they look like cousins.
I have had my TM FAs with Hobbytown drives for over 40 years and would not give them up. I do think the Proto and E&R FAs look much more like the real thing. I do have a number of both in NH colors. I do not have the MTH FAs but I think they look good .I don’t know how well they run I really like their New Haven McGinnis version but I think they on the high side for cost.
I’m inclined to think they just need replacing with the P2K FA-1’s that Walthers ALSO has. Those would be the ones with options like two different number boards and w and w/o db’s. And more. And they came with all that other stuff already on.
Yes IIRC the H-16-44 was announced but never released by TM or Walthers. Walthers did come out with an FM switcher, but a different locomotive entirely, an H-10-44. The earlier poster may be thinking of the Bachmann (or Atlas) H-16-44.
