train room flooring?
We are building a new house and my wife has graciously granted me a train room, not in the basement but on the second floor near the guest bedrooms. The questions comes as to what will the flooring be in the train room. This will be my first large layout(last ones were on 4x8 plywood).
What flooring is under your layouts? Hardwood, carpet, tile, what??
Concrete. I’m in the basement. At some point I’ll paint it and after the benchwork is built I’ll put down carpet runners in the aisles.
If you’re going to build models in there, I recommend wood. Unless you have a very short nap, you won’t find any small parts that wind up on the carpet…
Enjoy
Paul
Mine is on epoxy painted concrete, since it occupies a room that was designed to be a two car garage.
I recommend a smooth floor. There will be sawdust, plaster dust, and small parts that wind up on the floor. Dealing with that on carpet is a nightmare. You also don’t want your bench work to change height unevenly as the carpet mattes down under the weight.
PS:
Welcome to the forum.
[#welcome]
Sometime I too have to have a very short nap before continuing my search for very small parts![%-)]
I vote for carpeting if not in a basement and sometimes even then. I’ve had a few things dropped, that I was sure would break but the carpet pad provided enough bounce to save the day. Makes under the bench crawling much more comfortable but does preclude the use of a mechanic’s roller unless you lay a small sheet of plywood down lst.
Slippery/smooth/hardwood floors may not inspire as much liability assurance for an insurance claim.
Paranoid but something to consider anyway.
I have carpeting and I love it. It vacs up just fine. It does not show stains much and it is wonderful to walk on. I have a large “jewler’s apron” to catch the small parts that I drop by the work bench. I have heard, and made, all the arguements againt carpeting, but now that I have it, I love it.
Welcome [:)]
My layout room floor is tile. This both looks good, is easy to clean and find small parts on. It makes the room look good, and if you really mess it up by spilling paint or glue, you can just wipe it up or replace some tiles if really bad. I would not recommend a finished wood floor. It will get too messed up, and carpet is worse. Once the layout is finished, you can put down carpet runners of carpet tile.
[#welcome]
I have vinyl flooring under my layout. In a bedroom. Yes, vinyl flooring in a BR. {it was easier and cheaper to lay down after part of the floor had to be replaced and to cut down on allergens}
Finding small parts such as coupler springs on a carpet can be a nightmare.
Carpet with foam backer is easier to stand on for long periods of time than a hard surface. SO are rubber chefs mats, though and you won’t loose coupler springs with the rubber chefs mats.
Carpets can stain if you are careless and knock over a bottle of “railroad tie brown” or “grimy black”!
Tile can be nice, but I would take hardwood over tile anyday. both are durable and easy to find those durn small parts on.
The choice is yours. You will get as many opinions as there are floor types. ANd as many as there are model RR’s sitting on top the floor types. From as many modelers modeling RR’s on top of said floors.
Congratulations!
My layouts have resided the last 17 years in a second floor 11x15 room. Before I built my first room filling layout, I covered the wall to wall carpeting (over floorboards of course) with some thick plastic, and then picked up some carpet remnants to place over that.
When we got new carpeting, I did not replace the carpet in the train room, but took up the plastic and just placed a carpet remnant over the old wall to wall. I’m still careful about messing up the carpet, but it isn’t a critical thing so its OK.
Ohhh, having a layout in a climate controlled room is great. HOWEVER, you will probably end up doing all your wood butchering and the like in the garage or driveway, and then you will carry the stuff up (and down and up…) to the trainroom - without making a mess in the other parts of the house.
I have carpet in a finished basement. If something falls, it’s not that bad.
Mine is in a small trailer so the flooring is 3/4" plywood (not particle board or MDF) topped with linoleum tile. This proved to be somewhat dusty so I put down a cheap thin area rug. That seems to help keep the dust down but owing to the fact there are dirt roads all around us here there’s no escaping it. A good vacuuming of the rug keeps the dust problem at bay.
Linoleum cleans more easily, and small things that drop will be easier to find with eyes at floor level. Larger things will usually mean more pieces to find, but they’ll be easier to spot. [;)]
However, for appearance and comfort, it is hard to beat a good quality commercial grade carpet, the short pile kind that is often found in mall stores or hotel hallways. Then again, construction processes, particularly soldering and scenicing will almost always result in a point-outable boo boo. Glues that drip make really hard boo boos.
I read that…someplace.
-Crandell
In other words, use a carpet you can afford to lose.
Right now, my basement train room has a concrete floor. I could live with that, but eventually, for aesthetic reasons, I’d like to upgrade. I’ve considered a number of flooring materials. Recently, I saw garage flooring that fit together like pieces of a jigsaw puzzle. I haven’t yet priced those to see how cost effective they would be. I’d also like to put in ceiling tiles and skirting on the benchwork to hide the storage space below, but first things first. My main priority right now is to have the entire mainline completely scenicked. Then I can turn my attention toward the window dressing.
Commercial grade/ foam backed carpet for me. I got it from a jobsite that was replacing the flooring. It’s a darker color, goes good with the facia. If (when) I lose a part, the nap is short enough that a flashlight on the floor will see the shadow. It’s laid over a sealed concrete floor in a 30’x 42’ trainroom. Real easy on the feet, knees and legs. I like it!
No stains yet, but most stain-inducing work is done.
Terry
Kevin, congratulations on getting a train room, I have a train / garage my self.
I just got done doing the kitchen floor and I high recommend Novalis self sticking title. I used part number 0171374, it is 18 X 18 inch sections. Very easy to work with and very cost effective. I bought it by the box, 10 pieces are $20.00 now, it was $18.00 when I started. You can find it at Lowe’s. Here is a picture of it while I was doing the floor.
So far it has been very durable. Besides Tiff in the picture I have Shaddy a 140 pound Irish Wolfhound that loves to run in the house. She has yet to scratch the floor. All so Tiff, the little white dog. She will be 16 in a few months, lets just say here kidneys are not what they use to me. Tile is not coming up anywhere.
Cuda Ken and [#welcome] as well.
My layout is in a basement, so I sealed the floor with an epoxy paint. A word to the wise, DO NOT sprinkle the paint flecks they give you to spruce it up! Have you ever tried to find and N scale coupler on the floor when there are all these light and dark brown specs? [banghead] Anyway, after the benchwork was put up, I used a carpet tile from the local big box hardware store. It only is over the aisles, so the legs of the benchwork still rest on the concrete floor. If I get some solder, glue, or paint on it, I can just pull up that tile and replace it with another one. It really gave the room a finished look.
My trainroom is the basement, and with the exception of a small bathroom/shower, it is all mine. Floor is concrete obviously, but I laid vinyl tiles down 31 years ago, and about 20 years ago I laid carpet over the vinyl/concrete. The carpet is a commercial grade and has weathered time very nicely. Keeps the floor nice and warm while laying on my back doing wiring, etc.
Bob
My train room (non-climate-controlled garage) has a sealed concrete floor. At the moment, I put a cheap throw rug where I’m standing if I’m going to work in the same immediate area for a while. Sometime in the future I intend to pick up some carpet cutoffs and seconds (cheap!) to lay in the aisleways. As for the somewhat larger floor surface under the benchwork, since I don’t walk there and it will be concealed by under-fascia drapery, it will remain concrete.
My last layout before Nevada was in a carpeted room. I put sheet plastic over the carpet when I was working, both to protect the carpet and to simplify the hunt for vagrant parts. When the layout was removed, the carpet was clean and the missing parts roster was limited to a few coupler springs.
