I need help selecting a new transformer. I have a 4’x8’ O-scale “tabletop” type layout. Current devices are: Lionel NYC starter-set type steam engine/tender, RMT Beep Diesel loco, lighted caboose (1 for each engine), Lionel crossing gate w/ lights (wired to accessory power and operated via insulated track sections), 2 lighted bumpers, 2 O-31 Lionel remote switches, block target signal operated via 153-IR controller wired to accessory power, and I plan to add a rotary beacon and a couple more powered accessories (diesel engine pump station and maybe the Lionel Tower w/ figures that move about). I only run one engine at a time, and park the other on a seperate block-wired siding. Currently running a Lionel BW-80 and figure I am about at the limit of that unit. Don’t really want to ante up for a ZW quite yet. Any suggestions greatly appreciated. Thanks.
How about another CW-80 , use one for accessories the other for trains . I see about a dozen on e-bay everyday for well under $100.00 . johnnyc.
A Lionel postwar LW. It delivers 125 watts, has a whistle control, an excellent lighted dial that changes in intesity according to the throttle setting, and can be had usually for under $60.
The Lionel TW has most of the same features as above, but has 175 watts, and sells for under $80.
And, finally, the KW has two throttles and 190 watts.
I second ben’s LW. I love LW’s and have 3 on my layout. They are the best watt/buck out there. The ZW is over rated and can really only pull two trains not four. I would get a LW and use it on the train only. Use that 80 watter for all the other stuff.
Charlie
The LW,TW or KW are excellent choices for your present setup. If you are going to expand your engine roster with ones that have Railsounds[Lionel/K-Line] or Protosound 2[MTH], I’d reccomend that you buy a K-line Powerchief transformer— It has a output rating of 120W[the Lionel units are rated by input power] . It also has a bell & horn/whistle buttons to activate the sounds.
Lionel power house brute is th old 250 watt Z. I goes to 25 volts on each of 4 different outputs and does wonders for powering 4 different command mainlines.
You can set the max voltage on each main with the dial and you don;t have to mess with phasing different transformers together as it is in phase with itself.
I just happen to have a reconditioned one for sale now.
Check svc trains. dave roxin.
The Z is great–I have 3 of them–but be warned that it doesn’t have a whistle control or a reverse button, just those 4 knobs.
