In my 12x16 post-war layout, I have a ZW transformer with a common ground for the layout. Power is supplied to the track and to the fixed voltage plugs on the turn-outs(022 switches) from this transformer.
I also want to hook up a KW transformer to the same layout to use for accessories.
Can I use the same common ground that is conneccted to the ZW? or is another common ground needed for the KW transformer?
Do both transformers need to be somehow connected to each other?
The two transformers’ commons (terminals U of both transformers) need to be connected together, but only if you are powering 022-type turnouts or other accessories, like crossing gates or block signals, that connect to the track.
(There are no “grounds” involved. You can ground the transformer commons if you want to, but you won’t see any effect from that.)
You will probably see well-meant advice to “phase” the transformers. That is not necessary. In fact, there is some good reason to have the accessory transformer out-of-phase with the track transformer.
The Lionel KW and ZW will operate together if you tie the U terminals together but it gets funky with accessories because the KW splits a lot of voltages off in seperate circuits.
I used my ZWs inner B or C controls for switches and lights. If you want to have a common ground return then the U terminals need to be tied together and the transformers phased, wich basically means the line cords on both transformers need to be oriented the same way.
One thing to considder is the switches and controller eat up a lot of watts. I converted my controller and switch lamps to LEDs to reduce the wattage and heat.
