I’m a new-bee back again for more advice. You really helped with the wiring.
My layout: there are 4 train loops, lots of crossovers and switches, lots and
lots of accessories, some grades - one steep. three yards, a
turntable, and two transfer tables (lionel with the extension).
I am building it in steps. First step was the laying of the track. Next came the wiring. Thanks to your help, i’ve got the main power wiring figured out, i think. a 12g bus (10 different wire colors with white being the common) that go around the entire table, connecting every 10 feet with a terminal block - screw type - the wires have crimped spade connectors. this gives me 8 power blocks, the common and one spare wire. i expect to have a block for each of the four loops, and one for each of the 3 yards. the 8th block will be the steep incline that takes
looging/ore cars up the mountain, so to speak.
Now i want to hook up some power from transformer(s) to get a test
run of some equipment to make sure the grades and clearances are ok
before i lock the tracks down to the benchwork. I’ve got the accessories
temporarily located where i want them. now i want to see if it all
fits before i wire it all tighly.
i have planned to use 2 zw 275’s. is there a best way to hook this up.
two routes and 2 yards on one, two routes, 1 yard and the mountain
road on the other?
i will have additional transformer power for lights, accessories and
trackside signals. again there is a lot of this.
TMCC (accessory controllers, SC switch controllers, powermaster,
command base, block power controller, voltage controller and track
power controllers) and how to hook it all up will become my next
hurdle. things have gotten a lot more complicated since my first
layout in the 50’s…Wow!
but for now - can two transformers run this, as i have described it.
i can’t yet send a copy of the layo
