I was brought up short by a statement in Bob Keller’s article, “Choose the right transformer”, in the January CTT. He says, “While the postwar ZW may win in the studly looks department, a string of postwar Lionel no.1033s hooked up in series may get the job done just as well.” The 1033 doesn’t put out a lot of voltage, but just two of them could get you up to 32 volts, if that’s the point. I think that’s as much of a string as I would find useful. He may have meant to say “parallel” instead of “series”; but that’s not a good idea either: The slightest difference among voltage settings and the transformers will be pumping current from one to another rather than to the trains.
It’s also unfortunate that Bob didn’t explain the distinctions among transformer power, voltage, and current. For example, if 16 volts is not enough for a particular locomotive, there is no point in replacing a 90-watt Lionel 1033 with a 300-watt American Flyer 30B–the train won’t go any faster. There’s more to it than just power. The comment, “…long runs of track…require a more powerful transformer”, reinforces the fallacy that power loss, not voltage drop, is the enemy of a large layout and that a bigger transformer per se will solve the problem.
While I’m at it I might as well note that John Rusterholz’s article, “Wire a trackside signal to a Lionel switch motor”, applies only to 022 turnouts and others that shut off the switch-machine coil after throwing the points. It won’t work with Lionel O27 turnouts like the 1121, 1122, or 5121, for example.
And finally, I came across a couple of instances, in different articles, of the word “buss” incorrectly used instead of “bus”. As anyone can see by Googling “buss definition”, “buss” means “kiss”, and nothing else. I think this common spelling error might have originated with “Bussman” bran
Bob, the term “buss” was used in U.S. Navy Class A ELectrical School texts [at least in the late 1940s] in describing the heavy A,B &C switchboard bars in the Ship’s Service 440 power system . You have made the point about the spelling previously and your point is well taken. But I’m sure you are aware that field useage varies substantially even in the pristine world of EEs[8D], even if less so among old Sparktricians[D)] and novice model raILroaders[:)].
Is WEBSTER’S Greyhound [“bus”]3 phase or single[;)]?
I once saw a Lionel instruction manual for a 1033 or 1044(maybe even a 4090) that showed how to connect two of them in series. I think it was to show how to get more voltage to run Standard Gauge trains with postwar & newer transformers. If I recall, the 2nd transformer was used for it’s 5 volt fixed taps only in the circuit diagram.
I searched for “buss” and “bus” in NAVPERS books. The only instances I found on the Internet were two in 10548, Electricians Mate 3: “…on generator switchboard bus bars.” They may have spelled it “buss” somewhere; but I couldn’t find it. There’s a lot of misspelling and bad usage around; but I would hope that a publication like CTT would aspire to getting it right.
Although the Navy books were my introduction to electronics, after a childhood of messing with toy-train electricity, I have never forgiven them for deliberately trying to reverse the direction of electrical current. They produced generations of technicians who don’t speak the same language as the engineers that they work with.
By the way, notice that the Greyhound type of bus is the same word as the electrical bus. They are both from the Latin word omnibus, the dative plural of omnis, meaning “for all”. The one-s “bus” is completely unrelated to the two-s “buss”.
Rob, that’s certainly reasonable. Sixteen volts is barely enough to get a 773 to move. Two transformers in series are literally a string; but that’s not the word I would use unless I meant a greater number. How it fits in with the bigger-is-better message of Bob’s article, I don’t know.
I apologize–I did intend to make fun but not get you all crossways over such a nitppicking issue. Anyway we lesser types did manage to keep the lights on and guns firing during most naval battles.
I agree with Bob Nelson about not putting transformers in series, to me it is plain dangerous! There are many reasons not to do this but the most important reason is high end voltage.
With all the transformers being made today there should be one made to fit your voltage needs. Current makers of transformers for model trains include; Lionel, MTH, Bachmann, Atlas, MRC, LGB and probally a few others.
I happened to glance at Bob Keller’s article again and got so curious about his reference to, “Big power for a small price: Using several small transformers in series”, that I paid CTT $8.90 to send me a copy of the October, 1990, issue.
The article is by Ray Plummer and is actually titled, “Big power for a small price–Use a number of smaller transformers to operate your layout”. All Plummer was saying was to buy a pile of small transformers and hook them individually to blocks on the layout. There’s nothing about wiring them in series either in the title nor in the article. That’s a relief; but how did series transformer wiring got into Bob’s recommendations and even into the transmogrified article title?
Now don’t get the idea that I like Plummer’s recommendation. I still disapprove of running trains from block to block powered by different transformers, for reasons of fire safety that I have belabored endlessly here on the forum. But at least his proposal wasn’t as bizarre as Bob’s “string of…1033s hooked up in series [to] get the job done…”.
I found the manual I referenced above. It’s for the 783 Hudson, and it shows two 4090’s wired in series with the 2nd transformer used for it’s 5 volt fixed winding to boost the output to 21 volts total.
The online manual at Lionel.com has been revised with this section deleted.
The guys at CTT can’t seem to understand that more track feeders will accomplish more to overcome the voltage drop of track joints than a bigger transformer. A bigger transformer will only make the train go faster near the lockon.
Why not put them in series if you need a little more voltage ? I f you are watching things while running your trains , whats the big deal? I understand not needing 32 volts from 2 1033s but how about the method the old instruction manual reports?
Your valuable information is well taken and appreciated, especially that you intend for us to be safe and keep, not only our model trains intact, but our lives and homes.
I think I would advise against putting transformers in series unless you are very careful. Doing this would make it very easy to exceed the maximum current of the transformers. Some of the smaller transformers don’t have circuit breakers, and they could overheat and perhaps catch fire.
Years ago, when I was about 12 (1953), I remember using two Lionel Scout transformers in parallel to run a train. I was careful to phase the transformers properly, and to keep the controls at about the same setting. It worked OK. Why do you get more power out of two transformers in parallel than a single transformer, you may ask. It is because the transformer has a non-zero output resistance. For the smaller transformers, it can be several ohms. For a KW and Type V, it is about an ohm. For a 1034 it is about 1.5 ohms. This is why the voltage of the transformer drops when you put a load on it.
When you put two transformers in parallel, this output resistance keeps the currents from getting very large. For example, if you had the two outputs of a KW powering two blocks, and a train ran from one block to the next, and the two outputs were different by two volts, the current draw due to shorting the two outputs together would only be about 1 amp and would not harm the transformers even if the short continued for some time. With this said, let me say that Bob Nelson’s method of using switches to switch blocks from one transformer output to another so that a train is powered by a single transformer output as it goes between blocks is the best way to do things, and carries the least risk of a problem.
Lionel designs their transformers to have a fairly high output resistance because they are variacs. When the roller rolls across the windings, it shorts two windings together. The roller resistance and the transformer design limits the current in the shorted winding. This reduces the efficiency of the transforme
I don’t have a problem with using one transformer to boost another by a few volts, by someone who knows what he is doing. But “a string of…1033s” is over the top!
I agree that the fault current is less between smaller transformers; but you still can’t let the voltage difference get out of hand. And, in any case, there will be an inductive voltage kick each time the connection is broken, which can be bad news for some of the modern electronic locomotives.
All that aside, how did the article’s title change and its content get misrepresented twenty years later?
Suppose you have 20-ampere 120-volt branch circuits in your house, which is very possibly what you do have. You plug a 60-watt lamp into one of those circuits and it lights up, drawing 1/2 ampere of current. Now suppose you open up your panelboard and connect the lamp instead to the very large wires coming out of your 200-ampere main circuit breaker. It lights up just the same and draws the same 1/2 ampere that it did on the much smaller branch circuit. The only difference is that the first time, it draws 1/40 of the current that the circuit can supply, the second time it draws 1/400. But it doesn’t get any brighter just because the circuit can supply 10 times as much current. How much it draws depends only on the voltage supplied to it, 120 volts, up to the point where the circuit breaker trips.
The same thing happens with the 1033 and the 30B. The 1033 supplies 16 volts up to 5 amperes and the 30B supplies 15 volts, up to perhaps 15 or 20 amperes. As long as the train draws less than 5 amperes, it will behave the same with (almost) the same voltage. It doesn’t know how much more current the 30B could supply.
The only thing the 30B would buy you is the ability to run more or bigger trains, but still at the fairly low voltage of 15 volts. If all you have is a train or trains that don’t run fast enough at 16 volts but don’t draw more than the 5 amperes that the 1033 can supply at 16 volts, they will run no faster with the 5 amperes that the 30B will also supply, at 15 volts, perhaps a little slower because of that 1-volt difference.
I immediately got confused, but then I realized that you had a typo when you started out by saying 20-ampere when you intended to say 200-ampere. Just thought I would mention that in case anyone was confused. In any event, I was trying to imagine someone owning a house with 20 amp service in this day and age. [:D]
Let me ask a basic question about electricity as it relates to transformers.
I have a multimeter that that I periodically use for testing on my layout. Recently, I had reason to check the amount of power reaching the track from my old American Flyer 8B transformer.
My multimeter has instructions for measuring, among other things, both voltage and current. My assumption was that I wanted to check for voltage, and I did so getting a reading around 16 to 17 volts on the rails, so I assumed that everything was working properly with the transformer.
That being the case, why would I measure current? Or, put another way, what is the distinction between voltage and current?
