Transient Voltage Suppressors
I think I have read every post twice about using TVS diodes. I have ordered them and received them today. I am still confused about where they need to be wired into the track circuit. I use three vintage ZWs on my layout and run trains on six circuits using the AU and DU posts on each of the Zs. It appears to me that all I need to do to put the TVS’s in play is to connect them somehow to the A and U or D and U post of each transformer? One end of the diode to the A post and one end to the U post? This would take 6 diodes. The TVS I purchased are bidirectional so I don’t even need to worry about which end goes to the post? I guess they could also be connected to the track but I don’t see any advantage to this. I don’t use connectors as the leads are soldered to the rails. Am I on the right track? No pun intended. Thanks [:)]
You are on the right track! And you can connect them at the transformers or at the track or at any convenient point in-between. They could even go inside your locomotives.
Bidirectional TVSs are necessary because you are using AC voltage, with the polarity reversing 120 times each second. But the same alternation means that there is no polarity to worry about when installing them, as you figured out.
If I understand correctly then, a TVS diode could be soldered to the A and U lugs inside the case of my ZW and they would be completely functional and out of the way. A TVS diode installed in this way would protect any locomotive operating on that circuit? Okay then, a couple of more questions please? Will the TVS diode last forever? Can they be damaged or destoyed and need replacing? Will I ever know if they absorb a spike? Is there anything else I can do to protect my locomotive circuit boards? By the way, for those considering it, I ordered the 1.5KE36CA-E3 diodes from the Mouser web site. They were on backorder for about a week. Great service in my opinion and very reasonable (cheap) prices. Thanks to Bob Nelson for his patience and helpful advice. [oX)]
You’re welcome!
Yes, you can put them inside the case if you like. A TVS is not indestructable, but that “1.5K” in the part number means that it can take 1.5 kilowatts (for a short time). In this application, it is very unlikely they will have to handle enough energy that they will fail. You won’t know when they take a bullet for your electronics. The only additional thing that I can think to suggest is what I mentioned above–you could also put them into the locomotives. That way they would still be protected if you run them on someone else’s layout, while the TVSs on your layout would protect the other guy’s locomotives running on your layout.
You might find the Wikipedia entry an interesting read: http://en.wikipedia.org/wiki/Transient_voltage_suppression_diode
Unless a TVS diode fails catastrophically – apparently a very rare event – you won’t know if one has failed unless you have quite sophisticated test equipment; so my approach is:
  1. Use more than one on your layout. At current prices you can buy 'em by the bag; It’s unlikely that they wll all fail;
2 Plan to replace them every now and then, such as during once-a-year maintenance if you employ such a thing. For reasons of pure convenience I don’t ordinarily solder mine but simply bend them around posts or screws and snug them down.
It is much easier to attach them to the posts on the outside of the transformer case or across track-lockons than than it is to do so inside. You can extend the leads if you have to . Personally I use quite a few barrier strips and often attach the the TVS diodes there. Just remember that they go across (in parallel with) the power/common leads and not in series with them.
Bob has also written that the closer the TVS diode is to the device (s) you are trying to protect the better – another argument for using more than one per layout.
Don’t forget that you need BOTH TVS protection against voltage “spikes” for your table-top electronics AND properly-sized fuses or circuit-breakers to protect the transformer and it’s associated wiring from over-currents, i.e., “short-circuits.”
I had a friend ask me if this type TVS diode should be used on his HO layout? He is using locos with sound, etc. I told him I would think it was a good idea but I would check with the experts? If he is using DC power I would think a bidirectional diode would still be optimum? Thoughts?
He should be able to use a lower voltage rating, since his track voltage is probably 12 volts. He will need a bidirectional TVS, because his voltage polarity will change with direction of operation for conventional operation or will alternate rapidly if he is using DCC. With 12-volt power, a 1.5KE16CA might be a good choice.
Marty sent me this by e-mail. I am posting it for the benefit of anyone else who might be interested:
Bob, I understand your answer about using a lower voltage diode for HO since the voltage is usually less but since I have some 36 volt diodes will they still provide spike protection on his layout. Do the 36 volt diodes basically provide protection for circuits up to 36 volts? Thanks again.
Yes, the 36-volt ones will give almost as good protection, since the electronics probably won’t be damaged by anything between 16 and 36 volts. The 36-volt TVSs have a minimum breakdown voltage of 34.2, which is the peak voltage of an RMS voltage of 24.2. So they should not be used on circuits with a higher RMS voltage than that, but are okay below it. The HO voltage is just an alternating square wave; so the peak is the same as the RMS. The 16-volt TVS I suggested has a minimum breakdown voltage of 15.2, which should provide a margin in case his voltage is a little higher than 12; but the 36 volt device would simply provide (much) more margin, with a very slight additional risk.
Here is a link to the Vishay data sheet: http://www.vishay.com/docs/88301/15ke.pdf
With a recent (apparent) circuit board meltdown in my MTH PS-1 Dash-8, I guess it’s time to move into the TVS era. I thought my reset-able thermal circuit breakers would keep my boards safe, but I guess not. So, two questions about the TVS: First–you just wire them ACROSS the A and U terminals on my ZW? As in, what you’d do to create a short-circuit? Am I understanding that right? Do they not conduct power across them except in a spike situation to absorb it? Second–can I just walk in to my local electronic supply store (not Radio Shack, a real electronic supply store) and ask for a bidirectional 36 volt TVS? Does that sound realistic?
“First–you just wire them ACROSS the A and U terminals on my ZW?” Yes, if A is the terminal you are powering the track with. If you’re using any of the other terminals also, give each of them its own TVS.
“As in, what you’d do to create a short-circuit?” Yes. “Am I understanding that right?” Yes. “Do they not conduct power across them except in a spike situation to absorb it?” Yes.
“Second–can I just walk in to my local electronic supply store (not Radio Shack, a real electronic supply store) and ask for a bidirectional 36 volt TVS?” You need to specify the power rating also. The one I recommended in all those posts is rated at 1500 watts (for a very short time). “Does that sound realistic?” Yes. It is very popular; so it’s likely they have it if they have any.
OK. went to the electronics store yesterday, here’s what I came up with: a Phillips ECG 1V040, 5F AB unit. I’m going to try and post a pic here, not sure if it’ll work. Does this sound like what I need for my ZW and KW? Thanks!
What you got is better than nothing, but not nearly as good as the ones that I recommend. Yours is not a TVS (transient voltage suppressor) but an MOV (metal-oxide-varistor). It is not as fast and doesn’t clamp the voltage as tightly as a TVS.
Here are the data sheets for both devices: http://www.nteinc.com/Web_pgs/MOV.html http://www.vishay.com/docs/88301/15ke.pdf
And here are the Wikipedia articles for both types of devices, which may give you an idea of the differences: http://en.wikipedia.org/wiki/Varistor http://en.wikipedia.org/wiki/Transient_voltage_suppression_diode
Thanks, Bob. I didn’t think I liked the looks of what I bought, and when I finally got around to trying it out tonight, I like the results even less. I wired the MOV across the rails, removed the locomotives, and placed a test light on the circuit, then deliberately caused a short circuit. What happened was…nothing. As in, the same thing that happened before using the MOV: the thermal circuit breaker tripped after a few seconds, but nothing else happened to interrupt the power flow. So, I think I’m gonna return them and see if I can get the right item. Maybe I’ll print out the specs from Mouser and bring that with me. I knew you’d be able to tell if I was on the right…well, you know.
I went to Vishay’s web site to look at the data sheets for the TVSs. Bob Nelson has been quoting the capacity of the TVSs in watts, which is what the data sheets show. However, usually these devices are specified in joules which is the energy that they can dissipate, and is essentially constant regardless of the pulse width of the voltage spike or the peak voltage. I finally found the power dissipation spec on the last page: This Transient Voltage Suppressor diode has a pulse power rating of 1500 W for 1 ms. This is 1.5 joules. Figure 12 on the data sheet shows the transient thermal impedance which is 0.2 deg C/watt for a 1 msec pulse. 0.2 deg C/watt * 1500 watts is 300 deg C which will toast the TVS.
The data sheet is at http://www.vishay.com/docs/88301/15ke.pdf
The TVSs are going to be able to take a larger voltage spike if they are attached to a heat sink. The heat sink doesn’t have to be fancy, just a couple of terminals will work, but leads should be short. Soldering wires onto the TVS leads is NOT a good idea as the wires are not a good heat sink unless they are something like #`14, and even then, they are probably not as good as the terminals on a transformer.
Another problem with all this is that we really don’t know what the line voltage spike look like. Bob Nelson’s advice about using a 1500 watt TVS is good as this will probably take care of almost anything except for a direct lighting hit. If the lighting hits your neighbor’s house, your stuff may survive and it may not survive. If you want belt and suspenders, use a power strip with a surge suppressor in it along with several TVSs sprinkled around.
Bruce Baker
Taranwanderer, you misunderstand the function of the TVSs. They are to protect agains voltage spikes, not short circuits. When you ran your test, the TVS did exactly what it should have done which is nothing at all. If you generated any voltage spikes, they would have been too small and too quick to discern without some test equipment like an oscilloscope.
Bruce Baker
Bruce: you must have been inside my head as I was driving around in the snow today, because, at one point, I was thinking to myself: “Dude, (because that’s what I call myself when I’m driving around, Dude,) how do you know that MOV wasn’t doing it’s job? You can’t tell with a voltmeter what’s happening in the spike department, nor how much energy is being absorbed by that little monster, and it’s not going to interrupt the circuit like the breaker does.” So I guess just wiring them across the rails and shorting the track circuit out isn’t going to do much that an electronics challenged individual like myself will be able to see. Now, with that said, I returned to the electronics store today, returned the MOVs that I bought, and came out with these: http://www.nteinc.com/specs/4900to4999/pdf/nte4903_99.pdf According to the counter person, this was a direct cross-reference to the Mouser part (which I printed out and took with me.) So, is there really any way for me to know that these things are working, short of me buying an oscilloscope, or do I just wire them up and forget about 'em? Thanks again to all for the advice!
I would just wire them up and forget about them. Or you could do what Ben Franklin did and fly a kite in a thunderstorm. I don’t think you need to test them. Bob Nelson has recommended a heavy duty TVS, which should handle almost anything.
Bruce Baker
Cool, thanks for the info. I think I’ll forego the Ben Franklin step–as one of my favorite characters in one of my favorite movies (Mama Boucher in “The Waterboy”) said: “I invented electricity, Ben Franklin is the Devil!”
I have been reading this thread with interest. My question is this. Is this kind of protection needed or even valuable on the older post war Lionel trains or is is mostly for use on newer equipment with electronic circuit boards in the trains? Thanks.
No, it’s not particularly useful for older trains, which don’t have anything that needs protection from the inductive voltage spikes that seem to plague the newer stuff.
I’ve been doing some research on the way TVSs and MOVs are specified. I have found that the “10/1000 µs” power rating is the peak power calculated assuming constant clamping voltage and a particular current waveform. This is something called the “double-exponential” function. It’s a particular pulse with an approximate 10 microsecond rise time and an exponential decay to half the peak in 1 millisecond. It is described in Semtech AN-9608, “TVS Diode Application Note”, http://www.semtech.com/images/datasheet/transient_immunity_standards_bellcore_tr-nwt-001089_and_fcc_part_68.pdf . It is also Bellcore TR-NWT-001089, and U.S. Department of Agriculture, Rural Utilities Service, Rural Electrification Administration Bulletin 345-50, PE-60, “RUS Specification for Trunk Carrier Systems”.
I worked out this function and integrated it to find that it has the same area as a 1426-microsecond rectangular pulse with the same peak value. (I found a reference to it that gave this value as 1500 microseconds.) So one of these pulses with a peak power of 1500 watts, as specified for the 1.5KE TVS, dumps about 2.14 joules into the device. The MOV that we discussed is however specified directly as being able to handle 3.2 joules, delivered in the same way.
I found this relevant article from EDN magazine: http://www.edn.com/archives/1997/041097/08df_05.htm Here are excerpts com
