I have always wondered about the trick or formula for transitioning from an up or down grade to level track? Is there a formula or trick you guys use to figure out how long a transition track aught to be and at what % grade? I will be building a Helix with a 2.75% grade in HO. Any info would be greatly appreciated. Terry
I used a cookie cutter with 1/2 plywood. I placed the first support at twice the distance of the rest of the supports and allowed the plywood bend to create a parabolic curve. It worked quite well.
Chip - Tks for the info however I am not sure about the reference to the “Cookie Cutter”? I doubt seriously if my wifes cookie cutter would cut through 1/2 in plywood? I think I am missing something. Terry
The key is how much clearance your car or engine with the lowest to the rails profile. My first railroad almost forty years ago was to too steep a transition and as a kid I cut the pilot plates off an Athearn RDC so it wouldn’t scrape the rails during the transition. I would make the transition over an absolute minimum of 4’ in HO and possibly as much as 8’ if I had the room.
ndbprr - Thats what I was afraid of hitting the rails if I had it too short. So I guess based on how much room I have I should probably experiment and make it as long as practical watching the clearance of the steamers. Terry
Cookie cutting is cutting the plywood to the shape of the track and supporting it at various intervals to determine the height. I basically halved the grade for the first 12" and let the plywood tinsel properties create a smooth transition.
Hi Terry, I use 3/4" plywood for the subgrade (subroadbed) of my track. One of the reasons I like using material this thick is that it’s very hard to bend into a vertical curve that will cause trouble with even the longest HO scale equipment. At the top or bottom of any grade, I set one end of the plywood subgrade level and screw it in place, then set the other end to the grade (my steepest is 3 percent) and screw it in. The natural curve that forms in between works just fine. So long, Andy
