Hey guys, I just have a couple quick questions regarding going from Code 55 to code 70 Micro Engineering HO flex track. I have some transition rail joiners… but my question is whether or not I should shim the end of the code 55 flex track, or shim the entire thing… because I’m sure that the ties are the same height. I just want to avoid having humps and bumps between sections, because there will be some transitions on the same roadbed.
Or do you think just using the transition rail joiners without any shimming won’t create any real noticeable problems or humps?
thanks guys
