Yes but the consignee if Chicago is final destination would take a bill of lading from the steamship line from say Bangkok to Chicago. The steamship line would factor in there costs from USA W/coast unloading port to Chicago & add that into the rate they charge. This procedure makes the steamship line the RR customer from discharge port to destination city as listed on the bill of lading that shipper took from the steamship line at the port of origin. This procedure holds true no matter if the destination is Dallas, Houston, NY, Baltimore, Savannah, Atlanta etc…
[quote user=“futuremodal”]
Restuffing from ISO to boxcar allows the greatest load factor for the railroad, so assuming they can charge by the ton or by the pallet it provides the most profit per consist. Intermodal rates tend to be by the container regardless of contents, so it depends on if the railroad has different rates for domestic containers and ISO containers.
For BNSF LA to Chicago:
The domestic 53’ container rate is $1690 per box
The ISO 40’ container rate is $1409
http://www.bnsf.com/bnsf.was5/iprr/IPRRController
BNSF owns it’s own 5-pack (10 platform) well cars with 40’ wells, at 220’ each. The typical 53’ well car comes in a 3-pack (6 platforms), at 170’ each. Assuming a 5000’ train for each…
5000’ / 220 = 23 5-packs for 230 total containers.
5000’ / 170 = 29 3 packs for 174 total containers.
174 53’s per train = $294,040
230 40’s per same length train = $324,070
In this example, the ISO’s would produce more gross profit, but if there’s a mix and match of 40’ wells, 53’ wells, spine cars, etc. the difference shrinks, and if it’s all on 53’ well cars, the railroad then makes more with the 53
