Hi, all modelers, I was so delight with my new track: Trix, but there are problems about connection and power supply, i check a crossing 62624, and found 5 wires, 2 yellows, 2 blues, 1 brown. 1 yellow and 1 brown from signal I think, 2 blue and the other yellow from turnout mechanism, so where i can find power supply wires? Should i buy another wires? Thanks!
Usually, the Trix double slip crossing comes completely wired and a manual with a wiring diagram is included. The wires are color coded, with the brown and yellow wires being the power feed wires. The brown one goes straight to the power supply, whereas the yellow ones need to be connected through a push button switch.
Try to get the manual.
