Ok, truck is a Dodge with a 440, dwell is at 32 degress and timing is a 10 BTDC.[:)]
Now that I got that out of my system have a few questions about HO trains. I have a tuning tool for cleaning up the trucks, Mostly cheap LL, Bachman and build your self Athearn’s. I have up graded some of the rolling stock with Kadee plactic wheels, Atals with brass color axels and Proto 2000 wheels.
Few things I have ? about.
1 Some trucks the wheels spin better in one drection that the other?
2 How lose is to much? After cleaing axles want to go more to one side. I press on the trucks while cleaning, then with no pressuer spin the tuner. When it spins well I am done, but in a few cases axles are off set and are slop fit.
Now the string effect question. I was in MRR heaven for the last two days. Pulling 37 cars with BB Athearns. Then stuck on doubled headed PK’s and had to push my luck. After cleaning some trucks, replaced the wheels with PK 2000’s I added 5 cars. All rolled well and weight added.
Most of the cars are horn hooked and mounted on the trucks. I have up grade my track to 22 and 28 turns at the 2% grade.
From other tips I got from string effect question I placed the harder pullers close to the engine. In the middle I had tank cars, 40,000 gallon one I think so they are short, around 8. After them (LL and Bachman) I had real easy roller, worked Athearns and Bachmans that roll like a dreaam. All Athearns are using Kadee’s.
Derail happend in a spot I could not see, it was on a 22 inch turn. Want to guees what went over on there side? Yep the tankers.
Should shorter cars with truck mounted be toward the rear?
I all so think I know that there should be a 1/2 onces per 1" of car. I do not have a scale yet and been using pennys as weights. My rule of thumb has been 3 per 40 footer and tankers. (LL and Bachmans) and 50 footers 4 for lower cars and 6 for taller cars. Am I close?
