Trying to Learn about Brass Steam
I’m modeling Boston & Maine in HO (DCC) during the transition era. The problem is trying to find prototypical steam locomotives. Based on research, B&M had few if any USRA locomotives, and there steam engines had unique features (arched cab windows for instance), that other roads did not have. Consequently, manufacturers very rarely make B&M steam, and if they do, it is not very prototypical.
That being said, another option is to purchase used brass models. Based on internet searches, there are some used B&M steam brass models out there, but the cost is usually in the neighborhood of $500. Brass on ebay usually goes for more than prices you see in specialty shops. Without knowing much about brass, I am not willing to pay $500 for what could be an inferior product.
So I’m looking for any information I can find to enhance my knowledge on this subject.
Brass seems to be made in the Far East and imported to the Who are the good importers, and who do you stay away from? These are some of the names I have seen: PFM, PSC, KEY, GEM, OMI,
Dear reader,
Andy Sperandeo wrote an excellent article on this exact topic for the October 2005 issue of Model Railroader. You can get a copy of that issue by calling my colleagues in Customer Service at 1-800-533-6644.
Thanks for reading MR,
Terry Thompson
Terry:
Thanks for the reply. I have the article, it’s a good one, and I have read it a few times. I am just looking to see if I can get some additional details, and experiences from the very knowledgable participants of this forum
Steve
While I don’t model the B&M, I was quite taken with this little Mogul (pictured below) when I first saw it at a nearby hobbyshop. The store was having some sort of open house/celebration and had many items on sale. The unpainted loco was priced at $99.00, and had been part of the store owner’s personal collection. The end of the box shows it to be a Boston & Maine B-15 2-6-0, made in Korea for PFM. The cab windows had arched tops, and there was what I think was an ATS box mounted on one side of the boiler. There was also an optional snowplow pilot, included separately in the box.
The loco had a very small open-frame motor, and was an extemely poor runner. I replaced it with a small Sagami can motor, which was too large in diameter to allow the boiler/cab superstructure to be removed (this is a small locomotive), so I devised a way to mount the motor to the interior of the firebox. It was connected to the axle mounted worm and gear with slip-joint universals from Hobbytown: when the superstructure is removed, the motor and part of the drive shaft goes with it. Re-assembly requires the use of tweezers to align the drive train components. I crammed as much lead weight into the boiler as possible, and it’s now a decent puller, for its size, and an extemely smooth runner. I’ve since seen several of these locos for sale at train shows: the seller claimed that all had the original motors and were good runners. These may have been a later run of the same model. Prices ranged between $300.00 and $400.00. On my loco, cosmetic changes included removal of the ATS equipment, plus different lights and handrails. I also fabricated a set of brass sunshades, to disguise the arched cab window-tops, and added a working Kadee on the pilot. The sprung Fox-style tender trucks were replaced with a pair of Vulcans, and scratchbuilt footboards were added to the rear.
Hello WilmJunc, ebay can be a good place to buy brass if you are patient enough to keep an eye on the auctions for whatever interests you (provided it shows up occasionaly) for price, condition, “rarity”. I would recommend if at all possible to examine the engine in person and see it running yourself (if you buy locally).As for the various brands of brass you should realize that the older it is the more likely it might have been modified by a previous owner. If you decide to bid on an ebay auction here is a few tips:
Ask questions on condition, originality (whether it is still equipped with an open frame motor or upgraded to a can motor),look VERY closely at any photos (you would be amazed at what can be hidden in a photo clear or not),whether it has all of the parts or a tender (tenders are often a particular type for that specific locomotive or railroad and can be impossible and/or very expensive to get) missing parts can be very expensive or difficult to get.Ask the age, when it was made the older it is the less detailed it might be (no backhead detail, inferior driveline-motor,gearbox(es),drive shaft(s).If the seller doesn’t mention it ask how it runs or if it does.
You can also check out some of the established brass dealers, they often have extensive websites with photos, descriptions and lists of their inventory. Often times they also sell their wares on ebay.
Painted or unpainted brass I think will be a judgement call based on the condition and quality of the paint job, the condition of the loco itself.
Taking into account the age of the locomotive and whether it has been modified or even run they can be a mixed bag, if it was a “display only” piece it will probably need cleaning and lubrication at minimum or a rebuild or some tuning of the driveline (driveshafts, valve gear, siderods)The loco will probably be noisy, jerky prone to stalling, but put a bit of effort into it and you would be surprised how well it can run with some effort and patience.
Akane, West
Andrew:
Great post. A lot of good information.
As far as ebay, I do keep an eye on the auction, but the prices seem to always go way above what I’ve seen similar items listed for at dealers. Many times these ebay items are being sold from someone that is located a few thousand miles away so seeing the locomotive run before purchasing it is impossible.
A site/group that might come in handy when planning/deciding whether to revamp or replace a drive train is the Yahoo Repower and Regear Group (http://groups.yahoo.com/group/repowerandregear/). Joining the group and searching through their archives is a wealth of info about model locomotive drive trains.
Fred W
Dittoes to everything said above. Let me add a couple of thoughts. I like PFM for consistent quality, both in detail and operation. I have had good luck with Westside and Key. I consider Sunset a step down, but still good quality. It seems overpriced at some dealers, but you can do better on ebay if you don’t get carried away with the bidding. Of course that is true with any brand.
I recently bought on ebay a Key NYC 4-8-2. It was unpainted. Rather than paint it myself I went the pro route. I contracted with a dealer in your backyard, Bill Callahan, Gardner, MA, to paint and install DCC and lighting at a cost of $260. Considering the results, it was a bargain. If you decide on pro paint, plan to be patient because it will take a while. I waited 20 weeks. But good painters have a backlog of work and good quality takes time. It was tough to wait that long, but in the end it was well worth it.
Even if you decide to paint your own, I still recommend you check out Bill’s shop at www.bcenterpriseinc.com. Currently he has a B&M 4-8-2 in stock that is worth a look. He will give you good advice if you need it and good service, too.
That near-advertisement was unsolicited and I am in no way related to BC, except as a satisfied customer.
For brass importers,
Stay away from:
Gem
Alco Models
Tenshodo
Hallmark
Empire
Be wary of:
NJ/Custom Brass
Pacific Fast Mail (PFM)
Sunset
Oriental
Model Engineering Works (MEW)
Feel good about:
Overland (OMI)
Key
Precision Scale (PSC)
W&R
MTS
Railworks/Railway Classics
What I mean about the above is that when I say “stay away”, you better unless you can get it real cheap (and I mean really cheap), and that you have the skill to rebuild it if needed.
When I say “be wary”, be advised that quality of these importers varies… Some are excellent (my NJ/Custom Brass NH I-4 Pacific and L-1 Santa Fe are great runners), while some are icky (my NJ/Custom Brass NH I-5 Hudson). You may need some tweaking skills to get these to run correctly. Figure that you’re going to spend some money on these, but not too much.
When I say “feel good about”, I mean that these, with rare exceptions, are good to great running models. Almost all of them need no modification to run well. Figure on spending top dollar for these model importers…but they are usually worth it.
About paint: If possible, get “Factory Paint” (FP). These are the best. The next grade down is what most call “Custom Paint” (CP). These are professional quality paint jobs, as you can tell it’s not a Factory job but it still looks good. Then you have “Owner Painted” (OP), which can mean anything from a poor decal job to a model that was painted with a 5" brush…with automotive paint. Ick. Last, of course, is Unpainted (UP), but it will cost you easily $100 or more (some go for $150, some $200…it depends) for a custom painter to paint it for you. Figure that into your cost of the model when choosing.
As for model rebuilding, you’d best talk to some of the bigger brass dealers who do that kind of thing. An
You left out alot of brass and would like your opinion of them as some of the names are quite simular, also detailing can vary in quality from one brand to the next, I asume here you were talking about how well they run.
OK, here’s my take on brass steam, based on my own experiences with them.
First off, I’m an operator, not a collector. I’m also very interested in making my engines, whether brass, white metal or plastic, look as close to specific engines as I can (and I have a keener eye than many). The combination of these two biases means that I’m nowhere near a brass purist. What I’ve done to some brass models would make hardcore brass collectors shriek in horror.
Ray, some great information and some good advice in your well-considered reply. I totally agree with you about plastic steamers: much easier to work on and most can be made to both look and run better than brass, for a fraction of the cost. And while some of us may be interested in rebuilding/reworking our models to meet our own specific standards, there are many out there who are quite content if someone brings out a generic model with their favourite roadname on it, and they may or may not care how it runs.
By the way, thanks for the compliment; it’s much appreciated.
WilmJunc, Have you looked a Bowser kits? I do not know if they have any with B&M styling. Most of their kits are of PRR prototypes. They are fun and relatively easy to build. I built a small 0-4-0 that I later changed to a 2-4-0 when I found a casting that converted the loco to a cab-forward design. I still have the loco, but never converted it to DCC, o I arly run it, but have a nice little display (6-3" wide shelves) where I also display older trains and cars. I’ve had a little experience with brass. I repowered 3 different locos when I was abou 15-I’m 42 now. 2 of these were upgraded to DCC in 2001. I would be prepared to at least replace the motor with a can motor or maybe something cheap like a small 12VDC one like Radio Shack sells for like 5 bucks. You don’t have to spend a fotune on a loco that has already set you back $300-$400. Something else that often times is overlooked is th wheels. Older models were notorious for having the deep pizza cutter wheels and drivers. NWSL would be my suggestion for replacements. They havw an excellent selection, can get it or make it! I’ve not encounted drive problems other than alignment problems that I have overcome by using a short piece of tubing for a coupling. they are more forgiving than say a drive shaft a sharp angle. I would buy th loco unpainted and do it myself or have it done. One trick I hear of was an ethant is supposed to be used to clean he model & prepare the metal fo he paint to adhere. Plain ole vinegar will work just fine. I do know we wahed down some galvanized metal siding that would not hold paint & it still looks good 10 years later. You already have a good list or reliable manufacturers. Personally, I don’t use E-bay mainly because you can’t test run the engine. I have not seen brass that was DCC equipped from the facory, but in a steamer
WilmJunc,
I think you and I are in the same boat here. I also model the Boston & Maine Late Steam, early diesel time frame. I have been pretty successful in building a sizeable collection on B&M early diesel. Anything from FT’s, F-2’s, F-3’s and F-7’s, E-7’s, Bl-2’s, GP-7’s GP-9’s, GP-18’s, RS-3’s, S-1’s, S-2’s S-4’s and SW-9’s.
I have spent some time now building my steam collection up. I agree with you about the number of offerings and availability of B&M Steam, there simply isn’t much. What I have found is that if you want the real thing, you have 2 choices. Buy something “close” and kit bash the heck out of it, or be prepaired to drop some coin on some brass. I decided to take the jump into brass. Before I go into the brass part, I should tell you that there are a few offerings out there that you may want to consider in terms of plastic steamers for the B&M.
P2K has made 2 different road numbers of their 0-8-0 “herritage” steamers in B&M, I have both. They also have released undecorated examples of their 0-6-0 “herritage” steamer that can easily be decaled up to B&M, again I have 2. Bachmann has released 2 road numbers of their 2-8-0 in their “spectrum” line, I have both. These are not exact examples of what the B&M ran, but they are fairly close. The last plastic B&M steamer I have is an IHC 2-10-2. This model is not even close to what the B&M ran, the tender is not even close, but I’ve got to tell you in all honesty, she runs pretty nicely. I’ve heard tons of bad things about IHC products, but this new 2-10-2 is pretty sweet. I put a decoder in it and she performs well and pulls pretty well.
In the Brass catagory, I have been able to get my hands on a PFM 2-6-0 B-15. It doesn’t run and is currently in the shop being remotored, regeared, DCC converted with a Tsunami, having an LED headlight installed and painted. Next into the shop will be my Gem Models 4-8-2, R-1d to receive the same treatment. Once this is done, I will be sending in my
Michael:
It does sound like we are in the same boat. Wow, there has been a wealth of great information on this post. Thank you to everyone that has responded.
Yes the B&M diesels have been quite easy to obtain. I have the FT, F7, RS-2, RS-3, 44 Ton, S-4, and BL-2 so far.
As far as the PK2s, they are nice models but I believe that they USRA locos and I have not found historical information showing that B&M had USRA switchers. I did purchase a IHC Mogul last year just so that I could have steam on the layout. I thought that it was cheaply built, it was a pain to convert to DCC, and the tender was not even close to prototype. The Bachman Consolidation was also not that close to prototype.
I’m glad to that BLI and Roundhouse are coming out with some B&M models. We’ll see how close they look to real.
It sounds like you have been able to collect a fair amount of brass at under $400. What has been your best source?
Steve
