I just purchased the Tsu 1000 to fit into my Athearn Genesis Big Boy which has a Mrc decoder in it. I’m trying to figure out which purple wire on the Tsu is the positive wire. Their are 2 purple wires and 1 white wire in the middle of the 2 purple wires. Anyone know which one?
Speakers aren’t polarized per se, the reason for the markings is so that if you connect multiple speakers you can have them all in phase. If you hook up 2 speakers and they are out of phase, the sound will cancel out. FOr just one speaker it doesn’t matter which purple wire goes to which speaker terminal.
If you want two speakers hooked to your Tsunami decoder, if using 8 ohm speakers, DO NOT wire them in parallel - the resulting 4 ohm load will fry the amps output.
You have two choices - use two 4 ohm speakers in series for 8 ohms or two 8 ohm speakers for 16 ohms. Two 8 ohm speakers in series will actually put less stress on the amp (twice the resistance at 16 ohms, but half the current draw) so it will run cooler. A side benefit as well, you will be able to run the amp a bit harder without overloading it which is a bonus for driving lower frequencies.
