Tsunami 1000 sound at power up
Thanks. It did not work, but I think i’ve found the problem. It’s not the decoder at all, but a short from the locomotive to the track/programing track that is intermitent. It is a plated brass loco with plated brass truck side frames and I think that there is occasional contact–somewhere-- that caused the problem. I got it on the layout for a minute or so and all functions worked–sound, lights, fwd/rev-- after checking clearences. Later, it shur down, so I’ve got to just do some electrical troubleshooting. Then, I’ll redo CV 113 and see what happens.
Stay tuned.
mike
Just as a matter of curiosity, if you turn on the headlight and bell and then run the speed to zero, does the sound still mute?
If/when you do call Soundtraxx, please let us know what the solution is.
Regards
Still haven’t called [:(] But did confirm that leaving a function on does not help.
