Hello,
Has anyone here put an aftermarket Tsunami 2 decoder into a non sound Genesis 2.0 yet? I am putting one into a new 9-44CW. after programming all the sound CV.s it dawned on me the lighting CV’s and functions are different. Also the wiring with the way Athearn uses pads to separate the body’s is also confusing. It’s hard to tell where the ditch lights, walkway lights and number Board lights are attached.
Mine is a UP unit so I would normally just hook up the ditch lights to the rear and front headlights. But there has to be a more efficient way. Any help or advice would be greatly appreciated.
i have emailed Athearn about the problem but I would like to get it off my bench working. I am using a NCE power cab at my bench.
As it is programmed
F5 controls the ditchlights
F6 controls the number boards
it seems the walkway lights and the Ground lights are on all time.
thanks,
SB
