I didn’t take any pics, but last night I installed a TSU-1000 Tsunami in a modern Atlas Classic RS-11 (it came with white LED’s, not bulbs). It came out pretty well.
The speaker was the small oval speaker with it’s snap on enclosure. The decoder was the Alco 251 version of the Tsunami. The system used for testing and programming was a Digitrax Zephyr, using a DT300 throttle.
Opening the shell, it was obvious it would be a tight fit. First step was to remove all the black wire clamps and strip the Atlas board of all electrical connections. Next, I removed the LED head lights, and then took off the Atlas board from on top of the motor. The rear weight needed to go to make room for the speaker, so by removing the two screws holding it on, it came off.
Doing some quick measuring, it was clear that the decoder mounts had to go to make room for the decoder. Using a Xuron track nipper, I cut these flush with the top of the motor.
At this point, I had the four wires coming from the trucks, and the two wires on the motor. The motor wires were unsoldered, and the Tsunami decoder wires were cut to fit and soldered to the motor (orange wire goes on the top motor lead, gray on the side). The decoder was then taped to the top of the motor with 3M Magic tape so that the speaker wires and the capacitor were towards the rear.
The truck wires were long enough to connect to each other, so I did so and used the resulting connection to attach the red and black wires from the decoder. I used heat shrink tubing to insulate the connections.
Next, it was time to connect the LED’s. The red wire from the LED connects to the blue common wire on the decoder (I left this connection bare for adding the rear LED lead later), while the black wire on the LED connects to the white wire on the decoder. The LED was left in place on top of the metal weight at the front.
The rear LED’s black wire was then c
