Tsunami install in Bachmann 2-8-4 working mostly
Well I installed the Tsunami decoder in my Bachmann DCC Onboard 2-8-4
I took the Bachmann pc board out and wired the Tsunami as per directions
Everything works with my new DCE but the headlight comes on in reverse and the backup light doesn’t work at all
Double checked my wiring
Only thing I can see is that the Tsunami has an extra white wire in the rear where the speaker wires come out with no explanation what it is for (There is a white wire in the main bundle that goes to the headlight )
Any ideas ?
The white wire comming out of the back of the decoder is for the CHUFF CAM. If you have this connected to the rear light, I suggest you disconnect it.
In terms of the other lights, you are not clear on how you hooked them up. Did you remove the light board in the tender or did you just solder to the 8 pin connector? Have you turned the lights on? Do you have the Blue wire connected to the anode or cathode of the front light?
Can you post a pic of you install as this will help immensly.
David B
As per my post I took out the PC board and wired directly to the harness
Tsunami screwed up in their instructions
They say a TAN wire is for the cam but since there isn’t one I guess they meant the rear white wire
Yes I turned the lights on that is why I said the headlight comes on in reverse
And no I did not wire to the rear white wire as I said in my post it was an extra wire since the light white wire is in the main bundle
Note to self…refrain from helping those with bad attitudes.
I have installed about 200 Tsunamis for my customers, and no, Soundtraxx did not screw up their instructions…you did. Have fun figuring this out on your own…
David B
Yeah right TAN is now White
Right from their instruction sheet
“Connect the decoders TAN wire to the CAM Wiper switch”
And I specifically said I took the PC board out
And you didn’t come with the decoder an instruction sheet did and it says NOTHING about any cathode anode to the head light etcjust to wire to the headlight and back up light
YOU may know all this but they send instruction sheets
Nice to see that everyone is starting off the year in a good mood!!!
Anyway, you are correct in that the Tsunami instructions indicate that the chuff cam wire is supposed to be tan. Maybe it’s just a lighter shade of tan.
Concerning the lights, does that engine have bulbs or LEDs? If it does have LEDs, then the Tsunami installation guide does talk about resistors, anodes, and cathodes. See page 26 of the installation guide, http://www.soundtraxx.com/manuals/tsuinstallation.pdf. The excerpt from the text is as follows (if you have bulbs, then that’s a different story):
Using LEDs
Tsunami decoders may be used with LEDs, which also require a resistor to
be wired in series, typically about 680-ohms, 1/4W. Unlike lightbulbs, LEDs
are sensitive to polarity. The minus (-) cathode end of the LED (the
shorter of
the two
If the headlight is hooked to the blue and white, and comes on in reverse, and you HAVEN’T messed with CV29, then you have the motor wires, orange and grey, backwards. Rear light gets yellow and blue.
Didn’t mess with CV29 as I don’t know how
One thing when I first put it on the track The NCE cab said Decoder not recognized
I tried it later and it was OK for Entering the Loco Maybe somehow CV29 got changed ?
Like I said I don’t know how to do that
Wiring
Per Tsunami sheet
Grey Motor -
Orange Motor+
Bachmann’s PC board before unsoldering the wires
Red Motor-
Brown Motor +
I hooked the Tsunami Grey to the Bachmann Red
And the Tsunami Orange to the Bachmann Brown
Rear light has Yellow and Blue and Font White and Blue
Here is a pic of the board before unsoldering
You can see the Bachmann wiring
[quote user=“maxman”]
Using LEDs
shorter
One weird thing I just noticed
When I get my ear right over the tender and press the headlight switch I hear a whiring or whinning sound like something is reving up
Everything else works fine including sound effects so I will just run it with the headlight function turned off for now
I probably would have been better off wiring to an 8 pin connector as any resistors etc needed would be there but all the controversy over the capacitors inductors on my original thread had be leery
When I get my ear right over the tender and press the headlight switch I hear a whirring or whining sound like something is reving up
Hey
That whirring noise doesn’t sound good I would get a handle on the wiring before I left the lights on. Sorry I can’t help with the wiring. After I wire a decoder I forget how I did it until the next time. Old timers problem. [:-^]
Good luck.
Lee
Didn’t sound right to me either so like I said I have the light function off
Have you checked their on-line installation guide for reference?
Well, you still didn’t say whether you have bulbs or LEDs. The resistors are only for LEDs. If you take a look at the link I referenced, they also show the connections for bulbs. If I remember correctly, they show two different bulb voltages. Go back and look at that reference and see how it compares to the instructions that came with the decoder as well as how you have it connected.
Resistors are also for bulbs sometimes. For instance the Athearn Genesis loco’s use 1.5 volt bulbs. I don’t know what the Bachman loco’s use.
Another thing that should be done if it hasn’t already is to remove the capacitors from the motor if they’re installed.
I didn’t use the PC Board
I removed it and wired to the harness
Except for the resistors in the lights the instructions are the same as those that came with the decoder for the wiring polarity etc etc
I wired as they stated (Checked 3 times )
That whirling sound may be a simulated light dynamo reving up
I am going to start with some posts at the very start of this thread.
The TAN wire is very near white. You have to look real close to see any difference. But the tan (or white, call it what you like) comes off the decoder at the same end as the speaker wires ( violet).
I am not sure that there is a difference any more as I very seldom look at it, as I know it is the cam wire because it comes off the rear of the decoder.
The noise that you hear when you turn on a headlight is the dynamo sound .
If your unit has LED’s they are polarity sensitive. You need the blue wire to go to the positive lead of the LED’s and the function wire (White headlight - Yellow back light) goes to the short lead.
They need to be wired up right or they will not work.
Look at this link to help you with the LED’s. http://www.mrdccu.com/curriculum/Lighting/LED.htm
Look for polarity and it will show you which lead is positive and negitive.
Hope this might help.
