Tubular Track Recommendation
I prefer the O gauge track because the switches allow a longer freight or passenger car to go thru without hanging up compared to 027 track switches by Lionel, the 42 inch 027 switches have the same type of problem as their design is taken from the 027 switch.
027 switches by K-Line are designed differant and don’t have long car issues at the switches.
O gauge tubular track comes in a variety of curve sizes from 031 up to 072 and cutting an 072 curve and adding a straight track or half straight track between curve sections allows you to go up to a 96 inch curve. The older 022 switches from post war era work best.
Lee F.
Which has more strength, durability, realism, wich does locomotives run best on, ect.
Neither is very realistic. As to the other points O gauge definatley.
Strength/Durability: O31, due to heavier gauge metal used
Realism: O27, due to shorter rail, although neither is expecially realistic without adding extra ties and ballast
Best running: Depends on the radius of the curves and the switches used. There are plenty of people here who made smooth-running layouts with either kind. You should always use the widest curves you can.
Affordability: O27, since O27-profile O42 curves cost about the same as O31 curves, and O27 straights are cheap, cheap.
If you have a lot of one type of track I see no reason to scrap it and switch to the other.
Does anybody think that using green carpet to simulate grass is unrealistic or unappealing?
Hey, magic, a bit off topic on the carpet question. But my view is that if you like the way it looks, that’s all that matters. I am sure a purist would frown upon it, but all of us who like to cobble together pieces to make a nice running layout would use anything we can if we like the way it looks and works. Enjoy.
Not realistic at all. But I do it anyway. I use the indoor/outdoor stuff laid on the plywood, and the tubular track and accessories laid on top of that. Drill holes for the wires and track screws right through the carpet. I drill 1/4" holes through the 1x4 supports for the plywood as routing guides for the wires. Cables for operating tracks, accessory, and switch controllers are lengthened as necessary.
My reasons for having a 3 rail layout are for the fun of watching toy trains run and playing with operating accessories. For my realistic modeling urges, I do On30, HO, and HOn3.
just my experiences, yours may differ
Fred W
I always thought that to, that sclaes such as HO or sometime N should be for the realistic appearance, and O for the joy of running trains.
I know, I am a bit off topic…[V] … but lets not get [#offtopic] anymore!!!
(1) O gauge track beyond doubt. O27 is not intrinsically bad, but just never seemed very strong or solid to me.
(2) Re the carpet question, Scenic Express coarse burnt turf (or the color of your choice) is pretty cheap, fun to apply, and looks much more realistic.
What about woodland senics ready grass mat? Looks nice to.
Those are fine, but unless you get the discount one you are talking some serious comparative bucks to cover even a small layout like mine (9 x 6). Plus, you are also talking about a great deal of cutting and shaping. The turf simply drops into place (the canister, for anyone who does not know, is essentially a giant spice shaker). The fine turf makes a very nice, even lawn and the coarse is great for outside of town.
At the risk of offending EVERYONE at once, I’m using a mix of Fastrack and O-27. I decided I didn’t like the way the fastrack hangs over my 2%grade so I’m replacing it with tubular. I may change the interior sections with tubular and fastrack, but I need to settle on a final track plan. I am also using the Life Like grass as a nod to those days when my Dad have the layout when we were kids. 1 question I do have is how do you deal with seams on the grass? Also, how would you guys “decorate” the inclines? I have been debating on making my own rock wall, bass wood with wood beams or flat plastering with some grass. There really is no room for sloping as the rails ar so close.
Thanks!!
Hi, I don’t know if you are already using tublar track. But did you ever consider using a solid track. Atlas has a nice track and they have connectors for conecting to tublar track. It’s nickle silver, which is a very good conductor and is very durable. And also looks realistic. Just a thought from someone who is using it on his own layout.
Ralph
This is one of those brain teasers for the ages - is the glass half empty?
or half full?
You’re definitely not thinking like an engineer: it’s obvious that the glass is twice as big as it needs to be.
My thought was…best of both worlds…?[:-^]
Half full or half empty…just as long as its not half a[censored]!
Half-Fast? [:D]
Or " Half-Fastrac" !!
It seems like it’ll be half fast-rack…I may abaondon ship & go tubular all the way because of the cost. I am begininng to notice it’s pretty loud, too
I’m already half deaf…!
