Turbocharged/Supercharged
What’s the difference?
Norris, for turbo, the turbine is spun by gasses coming out of the cylinders at high temp and somewhat high pressure, so it is located somewhere in the exhaust manifold. The turbine drives another fan on the other end of the shaft that forces air into the intake manifold. Improves breathing.
For supercharger the fan is driven off the cam shaft, usually by a series of belts or chains. Same effect…the fan part forces more air into the piston side of the intake manifold from where the fan is spinning.
Did I respond as if I took your question too literally? Sorry if I did.
-Crandell
Why wouldn’t a diesel engine builder go for supercharging over turbo charging staright away? Is the energy from the exhaust considered free energy?
Now there you have me. In each case, at my level of knowledge and understanding, there is a hp requirement, so whatever work you want done, and design it to do, will cost that much shaft hp. I don’t know that it makes much difference whether you take the hp from the crank or from the exhaust gasses, except I would bet that the former is more “energetic” since it is direct…the crank spins quickly on acceleration, and the supercharger must spin up with it in concert. The turbo lags, and some of the gasses must bypass it. If you put a bigger turbo disk in there, will it blow more air at the other end…or will you just confound the exhaust pressure waves and create backpressures that are deleterious? I really don’t know, but I suspect as much.
I’ll shut up…someone else is sure to know.
-Crandell
P.S. - Norris, I do know that radial aircraft engines from The Big Exercise had both superchargers and PRT’s (power recovery turbines) in the cases of the Double Wasp configuration and anything that came later (not exactly sure of my terms here, but you will know what I mean).
All EMDs are Supercharged to improve scavenging of the cylinders with them being a 2 stroke Design. Alco right off the bat with their 244 had a Turbocharger on them. Their 539 switcher was not however in the S series and in the Rs-1 switchers. EMD did not come out with a Turbocharged design until UP forced them to with the Omaha designed GP 20. GE always had a Turbo on them.
BLW Lima and Hamilton IIRC went the Supercharger route. Fairbanks Morse had a Turbo on them. You also need to remember this it takes ALOT of exhaust flow to spin a turbo up to speed to get the pressure needed to boost the HP these engines produce. That is why EMD went with a clutch driven Turbo below a certain RPM it behaves like a Supercharger above that it is a Turbo. However on the non-turbo models aka the Switchers and the GP-38’s what they have on them is a standard Roots style Supercharger doing its normal job.
Turbo is short for turbo-supercharger as was use back in WW 2 era. As explained above some sort of air pump is used to aid in scavenging an engine and in the case of 2 stroke engine it is necessary just to run. A 4 stroke engine performs this function in the first and fourth stroke. Supercharging nets about one and one half to twice the power for an engine of a specific size. In racing engine you can really dial up the boost for more power but don’t stand next to it. EMD ran for years on naturally aspirated as its called, blower engine driven off the cam drive gears at the flywheel end. The problem with this system is that the blowers take about over 100 hp at 900 rpm the pump air. The turbo engine used exhaust gas to drive the supercharger impeller so the power saved is available at the flywheel. Being a 2 stroke the engine need some thing to pump air to get it started so they installed an overrunning clutch an at low loads at least its straight supercharger. EMD is the only application of this feature I think. Large 2 stroke engines in ships have motor driven blowers to get them started. 4 stroke engines, since the piston does it own scavenging, use a simple free spinning turbo but at low engine speed and load they are more of a blockage than any help. Some strategies to speed things up are to use multiple small turbos and to block off the unused ones at low loads and add them as the load increases. I think this is the system being tried on the new C175 CCAT engine on the PR43C locomotive being tested now. All this adds complication that is hard to maintain in a railroad environment. EMD’s blower engine is popular in a switching low load factor where only short bursts of power is needed and turbos aren’t much help and much more expensive to maitin. That’s why their are so many de-turbo old road engines. If you took a turbo off a $ stroke and added a blower that would speed things up there too.
You’re talking my language. Prop driven warplanes being one of my other interests.
creepycrank- Thanks for the explanation. Can you explain scavenging air a bit more please?
Hugh McInness (spelling?) wrote a nice book on turbochargers some 30 years ago - though technology has advanced since then, the basic concepts still apply.
First off, the pressure in the cylinder as the exhaust valve(s) opens is typically greater than twice ambient… As such, it forms a sonic flow, where the flow rate is relatively independent of back pressure, so a mild increase in back pressure due to the exhaust turbine is not going to affect the engines performance - i.e. it is pretty much free energy.
To give an idea of how much power can be recovered from an exhaust turbine, the Wright Turbo-Compound engines of the 1950’s typically got 30% more power for the same fuel consumption as the non-compound engines.
  • Erik
The Wright Turbo Compound radials were also maintenance-intensive, which goes a long way in explaining why DC-6’s lasted in service longer than DC-7’s and Super Constellations (my personal favorite).
Scavenging (on a two-stroke diesel) is the process of blowing out the exhaust gases after combustion and replacing them with fresh air for the next power stroke.
Are you sure?
All the FM locomotive applications I’m aware of were blower engines.
The FM engine was an opposed piston. I can’t think of how you could have a four stroke OP engine.
On any two stroke, you need a blower to provide scavanging air. There just isn’t enough oomph in the exhaust stream at low load and speed to do the job. You can do blower + turbo ala the Detroit 149, but a turbo alone won’t do.
edbenton not sure what you are referring to with your comment about ALCO. ALCO began experiments using the Buchi supercharging system on its 531 engine in the early 1930s. ALCO started turbocharging with Dr. Buchi’s turbocharger in 1937. Turbochargers were first used on HH900 and later HH1000 switchers. Engines used were the 531T, 538T, and finally the 539T in 1940. ALCO experimented with the turbocharged 241 engine which led to development of the 244 engine. This is all covered in Steinbrenner’s book. BTW the Dr. Buchi’s turbocharger was manufactured for ALCO by the Elliott Manufacturing Company of Jeannette, Pennsylvania starting in 1940.
Sleeve valves???
An article on FM’s published in Trains sometime in the mid-60’s specifically stated that no OP’s in locomotive service were turbocharged.
If you could ask the UP right now if they would take turbo’s off the old 40s to make more 38’s you would be thrown out the door for suggesting such a thing. There is a virtual fight going on to trade old geep38’s for older geep 40/39’s. The reason; Fire prevention. Poorly maintained turbo units do not throw NEAR as much oil out the stack (unless your on a C45AC) as poorly maintained blower equipped units. the only maintance item on a EMD turbo is the soakback pump and filter. I’ve seen 4 fail in 10 years. not much of a problem. Blowers on the other hand are VERY finicky; they seem to have a life of about 5 years before the seals and bearings start leaking oil right into airbox. blowers are much cheaper to change than a 20K for a turbo and 7K for a clutch pack. vs 12K for a blower. but when you change them every 5 years and there are 2 per unit the savings just aren’t there.
Sounds like it might be a good idea for UP to upgrade some 38-2s to GP22ECOs. It would give them better fuel economy, Tier 2 emissions, fewer power assemblies, and eliminate Roots blowers.
While not RR related as already brought up, the PRT on a R3350 radial engine 3 prts fed by 6 cylinders each adding 150hp each which is free hp. Always wandered why big engine builders haven`t tried this.
Detroit Diesel’s new engine the DD15 model is a turbo compound engine and they claim 5% reduction in fuel consumption as well as 10% more power- maybe not at the same time. About 25 years ago there was some excitement about using a “blow down” turbine running on the exhaust from the turbo on large marine engines. The power from this was to drive a generator for hotel power which is okay when they run for days at the same power level. To get back to locomotives I heard that Conrail ran some engine with turbo modified with a spool piece to replace the clutch. Probably generated more problems than it solved which is why all these schemes have fallen by the wayside. The airplane and marine propulsion as well as peaking generation are usually steady state at a high load factor that is necessary to get any benefit
The Trains article mentioned elsewhere referred to stationary power plant FM 38D 8-1/8 engines that were fitted with turbochargers.
I believe these were mounted in series with the existing roots blower, which if I recall correctly was driven by the top crankshaft, and at full power absorbed much of the power from the top crankshaft.
This was analogous to the turbocharged Detroit 149 series engine, which retained the same blower arrangement as the non-turbo engine. This worked well but didn’t provide the fuel economy advantages of the EMD clutch disengagement system which are significant and the only thing that allow the EMD engine to remain competitive with current four stroke engines in fuel consumption.
Interestingly, the Russians and Chinese built many hundreds more locomotives with unlicenced copies of FM 38D8-1/8 engines, and the majority of these were fitted with a turbocharger that allowed the power rating to be raised from 2400 HP for the twelve cylinder to 3000 HP. The final versions of the Russian TE-10 fitted with these engines were built up until 1990. These were four unit freight locomotives and several hundred were built.
M636C
The high endurance Coast Guard Cutters built in the 60’s have a combined gas turbine/diesel propulsion plant and the diesel are turbo charged OP’s rated at 3000 hp. Using a combined turbo blower is called 2 stage scavenging and at high power levels the turbo is supposed to be unload the blower so that its just windmilling. This is a lot of monkey motion and probably why a lot of 2 stroke designs have dropped by the wayside. There are oddly enough some some small 2 stroke diesel designs that have this belt and suspenders arrangement and seem to be quite successful. As far as I know EMD is the only design using an overrunning clutch design and it has several advantages that help with meeting EPA standards. It hasn’t been without its problems with the many complicated design such as clutch pack and spring packs to deal with drive line torsional wrecking the turbo.
