Hi All:
I got a problem, can’t find out what degree #5 or #6 turn out is. I trying to keep all my turn out at the lowest degrees because of the length of the cars and engines.
Hi All:
The higher the number, the lower degree. If you are running modern stuff you might want to go with a #8–although I’ve heard people going as high as a number 12.
Basically you can determine the angle from the number. A number 5 is one unit divergence for 5 units length. Unfortunately I don’t have my trig book in front of me to give you the formula. Most people go with the turnout number not the angle of divergence.
The formula would be arctan ( 1 / x ) where x is the turnout number.
For most of #6, it is 9.5 degree. For #4, it is 12.5. I don’t have the info for #5 at hand.
Jerry
My triangle.exe program (a little freeware utility I found) gives the following:
#4: 14.4 deg.
#5: 11.5 deg
#6: 9.6 deg.
#8: 7.2 deg.
