Is it possible to turn off all of the signal heads of a specifc signal signal to make it look like the signal has failed. I will be using DCC to control the signal aspects.
There are lots of combinations of hardware/software that can be used to drive signal heads, so I would imagine it depends on the specific combination you’re going to use.
But since approach-lit signals are a thing, it should certainly be possible.
of course it’s possible
there’s no reason you couldn’t add a switch to simply unpower the LED if not add a pseudo aspect that results in a lamp being black
The question is, why would you want to do that? Its a relatively rare thing.
I am writing a program to run my railroad that will incorporate everything that a real railroad encounters including weather. One of the things that I will incorporate is defects such as a signal going dark, any or all of the defect detectors or a bad switch, etc.
i’m curious when your program would decide to create such a problem? 1 in a 1000 times?
as suggested, some software determines aspect to generate (STOP, APPROACH, CLEAR, …) and relies on other hardware to determine how to indicate it (red, yellow, green, …). you could also inclulde pseudo aspects (e.g. CLEAR-DARK) that indicate a dark lamp. (what about a faulty semaphore.
besides determine that a detector is faulty, do you also want to randomize what it reports: false occupied or false unoccupied.
presuambly a faluty switch is similarly handled by misreporting it’s position. does this mean the interlocking logic simply forces a STOP indication because the desired switch position doesn’t match the reported position.
seems that a “defect simulator” would be a separate module that interfaces between the control program and the layout peripherals and randomly cause these defects. presumably a defect simulator could easily be removed or disabled
For signals to be dark due to a failure is rather rare. In case of line power failure, there is normally battery chests to minimally keep the lamp powered. By default, the signal mechanism drops to the red lens when power is lost, so the crew would at least get a red indicator regardless of actual track conditions.
Some railroads at one time did go to a dark indicator when there was no activity within two (or more) blocks in either direction from the signal. The concept was nothing more than a conservation attempt.
Mark.
The frequency of a signal losing inication has not been determined since I have not written that piece of code yet. The indication of when a block is occupied will be handled by a block occupancy detector which will report back to the ctc display showing where the train is. That module is already written. BTW: I am writing my program using the Java programming language and using a sql database to store all of the data that is used by the program.
Well if realism is what you are after you could always cut the wires. Then you could station a flagger there until the signal maintainers could troubleshoot and fix it. Maybe not.
Maybe I’m missing something here, but how can you be writing the program to control the hardware if you don’t know what the hardware’s capabilities are?
Also, you do know that an open source project written in Java to do all this (and a whole lot more), with a good number of prototype-specific signaling systems included, already exists? See https://www.jmri.org/xml/signals/
I do know wht the capabilities of the hardware are (Digitrax has everything that I need). I will be using pieces of the JMRI code. I wil incorporate the CTC capabilites and have written parts of my program to use for example a python script to stop a train if it violates the PTC rules. The full PTC module logic has already been written.
Okay, I guess it must be me, because I’m having a hard time understanding why you’d be asking this:
…if you’re also telling us this:
Oh well, doesn’t matter. Question asked and answered.
As already mentioned prototype systems have had a number of redundant safety features going WAY back.
Component failure, like a bad relay, almost always just results in a restrictive indication. Batteries back up the regular power supply, lamps are/where replaced on schedules before typical failure age.
Do what ever makes it fun for you, but I don’t model disaster, or crime.
Sheldon
