turnout control circuit
I designed a turnout control circuit cicra 1985 that worked with tortouse units and i believed was based on Forrest Mims’ radio shack booklet on operational amplifiers.
The circuit used two momentary pushbuttons,
#1 provided + voltage to the tortoise
#2 provided - voltage to the tortoise
When used in a yard/lader situtation, the button pushed changed all required turnouts to get in or out of that track to the required direction.
My 30 year old memory, not so good.
I do recall the circuit was simple with few parts.
Any help would be appreciated
Sornjs,
Do You recall what book it was in? There are many books out by Him:
https://www.google.com/search?q=forrest+mims+circuit+scrapbook+pdf&safe=active&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjCgqr_8LHYAhVmct8KHc3xD5UQsAQIQg&biw=1229&bih=587#imgrc=zCOJNFloWNdFqM:
He used to have circuits in the Popular Mechanics/Science/ Electronics Mags of long ago.
Good Luck! [:D]
Frank
Check my Google Drive and see if this is the book your looking for. The link below is a sharable link and should work.
https://drive.google.com/file/d/1nccR7XFOBR8-Cz-Upis8Zl4-h4Sc79tN/view?usp=sharing
Mel
My Model Railroad
To operate a Tortoise via two pushbuttons would need something more like a flip-flop than an opamp.
There was one posted here in 2009, uses a 556 timer chip. Unfortunately the OP of that one has not decided to pay for Photobucket so his image links witht he schematic and board layout are all dead.
However - it’s a basic 556 circuit and of course Rob Paisley has the same thing:
http://www.circuitous.ca/556Stall08.html
Doesn’t get much simpler, a 556 and 2x 10K resistors per switch machine. Push one button, Tortoise moves one way, push the other, it moves the opposite way.
latching the pushbutton can control a single turnout, but isn’t more logic required to control multiple turnouts on a yard ladder?
Design procedure for yard ladder control using slow-motion switch motors (but there may be better ways of doing this).
while the above uses a dual-pole rotary switch, sounds like you’re interested in a single button to align all the turnouts to a particular yard track?
Push Buttons… BAH!
Big boys go with BIG TOYS!
ROAR
There is more recent circuitry to do what you want to do.
I power my Tortoises from a DC power pack.
I control my passenger station yard ladder with an NCE Mini Panel and a series of momentary push buttons mounted on a control panel.
Each push button controls the entire route (multiple Tortoise controlled turnouts) into a specified station track on the ladder. The Mini Panel is programmed to automatically select the route when a particular momentary button is pushed on the control panel.
