I took a look at these. They are pretty nice and the cost per turnout seems reasonable until you add in the cost of the MotoDs. I didn’t see whre they support cascaded routes. They might but I can’t find it in the documentation. It tends to indicate iot might via the serial bus but it isn’t definitive. Also I see they don’t have loop prevention for the route programming. Digitrax DS64s have loop prevention and support cascaded routes. Just something to consider.
Calflash, what does your system do that I can’t do with a hot probe and a handful of diodes? Specifically, I have a diode matrix that allows me to select the one inbound route for my train entering staging, out of two separate yards with eleven total tracks plus a bypass (to passenger staging) and a motor pocket. Wiring required? ONE wire per turnout, plus a hot bus to the probe and a turnout common connection back to the dedicated 3-amp power supply that powers only that zone’s turnouts and a couple of indicator lamps.
Everyone to his own choice and methods, but with walkaround controls I prefer not to be tied to a control panel hense the use of DCC controlled turnouts. Also it provides a simple method for unfamiliar operators to simply enter a macro for the track or route they want. My approach possibly not yours.
Cal
