This newbie needs help with turnout indicator lights. I am in the process of building an N scale Kato track layout, using the NCE Power Pro starter set.
I was looking into ordering Digitrax DS 64 stationary decoders to control my turnouts and was wondering if there is a turnout signal indicator product (that will indicate whether the turnout is straight, green, or turned, red) that will work with N scale,Kato #6, powered turnouts and Digitrax DS 64 Stationary decoders?
What have other Kato users done to have signal indicator lights?
How do you plan to switch turnout (e.g. Tortoise, Rix, etc.??) If you use a Tortoise, it is easy. Just hook up LED’s to the outputs and BAM… you got lights… www.wiringfordcc.com has the plans for all this if you want.
Well, I don’t know much about using the DCC signal from the mentioned stationary decoder, but if you plan on using motors, the ones with outputs (e.g. Tortoise) make it really simple. If you use the decoder, you may get stuck with using the signalled vs. the ACTUAL position… subtle difference that matters not to me, but to some “experts” it does.
Brian
P.S. If you are using the power from your procab to power the tortoises, it will suck some of the juice from your layout…
It seems that the original poster is using the Kato Unitrack product and the switch motors are built-in to the turnout, so no Tortoise or other switch machine/motor is needed. The problem still exists about getting an indication of turnout position.
That is correct, the Kato turnouts have the motors built into the turnouts, they will be powered through the the dcc digitrax stationary switch decoder which will have a separate power feed.
If the Kato turnout motors are solenoid motors (which I think they are), then they only have power to them the instant the turnout is thrown. There is no continuous power being fed to them. If this is the case, there is a way to make lighted turnout indicators for them, but it’s not for the faint of heart; requires soldering a bunch of electronic components together. Maybe more trouble than you might want, but then again, maybe not. Check out the following website and click on “more circuits” on the left:
I am in the process of building the indicator circuits for my twin-coil Atlas turnout machines, and it took me several evenings to get half of my 14 turnouts done. I still have 7 left waiting for me when I get back from Iraq.
You may or may not be able to make it out on the picture, but what I did was use DPDT switches that pointed the the direction of the turnout and lit the appropriate light, then had a MOM to activate it. So basically for each move, you threw a switch to light the light, then pushed a button to throw the turnout.
DS64 decoders can handle both bipolar (Kato Unitrak 2 wire type) and/or three wire twincoil turnouts (Atlas,Peco and others).What I don’t know is if they can handle both types at the same time,given that they have distinct outputs for both these momentary power modes.But if such is the case,the three wire outputs of the DS64 could be linked to an Atlas no.200 Snap Relay to operate lights.Just an idea…
NCE Switch-Kat. Can have indicator lights and push button control. For the indicator lights you have to solder the light leads to the board and will only control 1 turnout. I was thinking about the same thing.
This is some task for someone who built a model rail road 14 years ago. I figured I would jump into DCC and ordered the NCE Power Cab. After debating with myself whether or not to by switch decoders I finally decided yes, and now I’m up to turnout indicator lights. Wow.
I think all order one DS 64 for my yard which will go without indicator lights and also order 6 or so switch kats and connect the indicator lights to them.
Does anyone know which LED indicator lights I should order and from whom?
Will the new atlas signals work here with the switch kats?
Glenn - keep me posted interested in hearing about your progress
I have a quick question regarding the switch kat switches, If I purchase the switch kats - where do you house them ? I’m not sure where to house the circuit board. I plan on housing my NCE main power cirrcuit board in a small cardboard box which I’ll paint and add terrain effects.
The switch kats pose an interesting problem or issue. I think they are 3" in lenght, any suggestions?
I’ve never opened a kato switch even if I could this board is probably to large to fit in the switch. I don’t think it would be wise to place the board under the switch.
My layout is in a cold gargage and is constructed with foam which sits flat on tables, sounder the layout is not viable
I’ve wired up indicator lights to cheap relays which I activate in parallel with the switch machines. I got my relays at Demar Electronics, but I think they have them a lot cheaper at www.allelectronics.com. I used DC relays, which will not work properly on AC. Once I built a Capacitive Discharge circuit, both my turnouts and the relays worked much better. (The CD circuit is always DC.) The relays I got are polarity sensitive, unlike the twin-coil swich machines, so that’s something else to watch out for.
I used two-color, 3-lead Red/Green LEDs for my indicators. I put them both on the control panel and trackside as signals on the frog-ends of turnouts in the tunnels.
Well ususally you will find that the LEDs and the housings are sold seperate but sometimes, and for a premium cost too, you can find them together.
FYI, i use Radio Shacks website as a starting point as it helps my ‘worst case’ $$ planning when specing out a project. http://www.newark.com is a good bulk item/research shop.
A semi-mechanical solution which I have used successfully with HO Unitack is to glue a magnetic latching reed switch to the bottom of the turnout. Pre-wire the reed switch, then use a slow-setting adhesive such as caulk or slow-set epoxy and position the switch so it is activated by the movement f the magnetic coil in the built-in switch machine. Since the reed switch is only single-pole (i.e. on-off) you’ll also need a cheap relay. A key advantage of this system over mst of the various electronic solutions is that it has “memory” - i.e. the LED indicators will be accurate when you power up the control panel.
