Hi!
As background, I’m 65, and building what I consider to be my last layout. Its HO, 11x15, with a main level and lower level staging/storage area. It is a “replacement” for my previous layout (1993-2008), and incorporates what I found “right” with the previous one, and sidesteps what I considered “wrong”.
The previous layout was DC, and had one major and one minor control panel. The control panels had amp/volt meters, reversing switches, and a plethora of block switches and turnout controls. They were impressive, but sure could be complicated if you hadn’t run trains for a few days. For power, I had two MRC Controlmaster 20s for operation and a Controlmaster 1 for turnouts & lighting.
The new layout has completed benchwork, with the lower level and the main level double mainline trackage all in place. It is DCC (Digitrax with 2 boosters, 2 dt400 throttles, 8 breakers) and all DCC wiring is in place and tested. Existing trackage is also tested, and the bugs have been exterminated!
My next step is wiring in the turnout controls for those in place. While I will use Caboose Hobbies sprung ground throws for those close at hand, I’m using Atlas above/below solenoids for the others. Yes, I know there are more realistic ones out there, but these are easier (for me) to work with, and can be camoflauged (spell) without too much trouble.
The layout is essentially a room filling Oval with a duckunder to get into the center. The DU is high enough that it is not a major journey for my lousy knees and arthritic shoulder.
I put in some accessory bus wires around the layout about 4 inches or so from the inside fascia boards. I used 14 awg, with two sets (one for each half of the layout) connected to the Controlmaster 1. From these bus wires, I soldered
