Turnouts within a reversing loop
Hi all. I’m planning out the wiring for my staging yard, and ran into a question I can’t quite figure out.
My staging yard has a reverse loop on one end for which I plan on using a Tam Valley Dual Frog Juicer to control the polarity reversing, as I have those on hand from the previous version of the layout. The issue is that in order to accomodate my longest mainline trains, I want a reversing section at least 8 ft long, and I don’t have the room to push the crossover that creates the reversing loop out of the loop. I can get close which creates a reversing loop about 6 ft long, but that limits my train lengths to less than what the rest of the layout was designed around.
Can I include the crossover turnouts within the reversing loop? I’d have to wire them to the output of the dual frog juicer powering the reversing section instead of the bus, but I don’t know how that might affect the abiity of the juicer to catch the wrong-polarity situation. I’m not sure why it wouldn’t work, but I’ve never tested it. If this is a workable solution, I then have a reversing section about 9 foot in length, which would be ideal.
This is on a DCC N scale layout with Digitrax DCS210, and staging yard on a separate power district from the main level but not currently boosted. I’ve run reversing loops before, just never with a need to have anything within them until now.
Thanks,
Jason
Feel free to include whatever track arrangement you need in order to accommodate your longest imagined train. As long as that length, turnouts and all, is fully gapped AND can only be fed power by the reverser’s outputs, you should be good.
The idea is that any one gap, anywhere on the layout, can be reversed if needs be. That’s what the reverser must monitor and switch when there’s a conflict under any one metal tire. Conventionally, we in the hobby prefer that the reverser only manages a small, but necessary, gapped length while the rest of the layout gets ‘normal’ DCC power from the bus.
Two things to remember:
The decoder doesn’t care what’s happening under it as long as any change takes place fully, in a very few milliseconds.
Technically, you don’t have to include the entire train length in the reversed section. From my understanding, you only need to avoid having two metal tires crossing two gaps concurrently where there is a conflict at both of them. Then you will confound the reverser. Digital Specialties, in their instructions for the PSX-AR, says when your trains are perforce going to be longer than your gapped and reversed section, you should make two (2) pairs of gaps at each end of the reversed section, and not just the single pair of gaps. You space each pair just a couple of hairs wider in separation than the longest truck, say a three axled heavyweight passenger car. This creates about 1.75" of dead rails at each end, unfortunately, but that should not bother most locomotives at all. Meanwhile, outside the reversed length, you have metal tires that are drivers and truck wheels that either don’t need reversing or they don’t care.
I don’t think you can do what you intend.
The reversing loop starts or ends, depending on which way you look at it, at one turnout where the inside rail connects to the outside rail. The loop is sometimes called a ballon track for that reason.
You can’t have that turnout inside or outside the reversing loop because it starts and ends the reversing loop. That turnout creates the reversing loop.
If you have a double crossover at the start or end of the reversing loop then that gets tricky. The actual reversing section in that case is the portion of that double crossover that is a diamond crossing. You really don’t want to be trying to wire that.
Can you describe your loop in a little more detail? Single track loop with one turnout connecting the two ends of the loop is a usual form of reversing loop. A crossover is a different sort of reversing section if it is a reversing section at all.
Crossover implies a double track. Not the same at all.
there’s must be more to this because a train obviously can’t go back through a turnout if the back end hasn’t cleared the turnout
Hi all. Sorry for the delay; my old MRR subscription was under a compromised email account so I switched it up to my normal email, but I’m going through the first-posts moderated delay again.
Mike and Greg are correct, and I didn’t fully describe the track organization. The reversing loop isn’t a balloon off of a single turnout, but rather at the end of double-track mainline. The turnout I reference is the crossover. If I didn’t have the crossover, I’d not have a reversing section, just an oval. (Well, not at all an oval in plan, but electrically it’d be a simple oval.)
Technically, that crossover isn’t from mainline to mainline, but mainline to a stud ended siding which enables the reversing action. The issue is compounded in that the two mainlines do not enter the staging yard parallel, like they are on the main deck of the layout. So one of my mainlines will be wired in with the same polarity with all the yard tracks (say, A rail away, B rail close), while the other mainline is arriving mid-yard reversed (B rail away, A rail close). If I didn’t have the crossover, no problem, the off-polarity main would just continue around the turnback curve to the ladder and it’d be happily aligned with the other mainline, but I’d loose my method of reversing my engines. But that crossover would have to be within the reversing section; if not, I’d create a dead short.
However, I figured out an alternative that I’m happy with. The reversing route is purely to reverse the directions of locos, but for the rest of the consist that isn’t an issue. So instead of putting the reversing section on the mainline, I’ve confined it to that spur track connecting the off-polarity sections. It’s more than long enough to handle my longest motive lashups (I have a couple A/B sets of F3s that I someday want to run as an ABBA set, although I haven’t done so yet. Not that an ABBA set need to be turned around, but it’s by far the longest lashup I&
What I’ve done for a Wye in my DCC mainlines (creating a reversing section) is wire in a manual DPDT for that particular section. Mine is an around the room shelf layout with wireless ESU throttle so I intend to “drive the train” following it around the room. I put the DPDT right at the turnout which is also a manual flick control (Peco, Walthers or ME are all manually controlled). Then I’m right there as my train approaches and I set the turnout and polarity right there.
Because you have created a pretty short reversing section you may be better off not trying to automate the polarity control. I know the reversing section seems long but if you think about it you may agree with me that in reality it’s very short.
DCC is very tolerant of short reversing sections in that the timing of polarity reversal doesn’t change locomotive direction. I’m thinking with a manual DPDT switch you will have plenty of time to decide which route the locomotive needs to take and set the switch appropriately.
One important thing I’ve learned building two (well three now) layouts in two years is automation and remote electric control aren’t necessarily the best way to go. Keeping things manual is a lot less work, much cheaper and can actually work better.
A wireless throttle is tremendous fun compared to any tethered system, just btw. You can get as close to the action or as far away as you choose whenever you like. Well worth the money.
One thing to be aware of is the current capacity of the auto reverse circuit. While you can do a lot of things within a reverse loop or crossover track, you may find the auto reverse circuit is somewhat limited.
My crossover reversing track has a 5-stall roundhouse on one end and a six-track yard on the other. I have kill switches so the roundhouse stall tracks are not normally live, and usually use only one switcher in the yard, so I keep my current demands low.
Thanks Mike. Mine is also shelf around the room with wireless throttles, but Digitrax in my case. Agree 100% that not everything needs automation; I don’t even have Tortoises installed yet (Peco, so wire sprung turnouts) so at present everything I do is manual. But my room is not large, and manually managing it isn’t really an issue.
My reversing section is definitely short. I think it’s now all of 24", as planned (ran out of rail joiners, so it hasn’t been roughed in yet. Hopefully will have a chance to lay in the connecting trackage and test the reversing section by the end of the week). As I said, long enough for my longest conceivable engine lashups, but that’s about it.
Thanks,
Jason
Hi Mr. Beasley,
Current draw within the loop was something I was a little worried about, but I don’t think I’ll have an issues. The staging yard deck is on a second power district and being a lone wolf operator, it normally wouldn’t have anything running on the whole deck except for the engine/consist traversing the reversing section. My other motive power will be hostled on stub-ended engine tracks after dropping their strings in the main yard, and I can turn off those off with simple SPST switchs (which will also take care of all the extraneous noise of the auto-engine starts at layout power-up).
Thanks,
Jason
EDIT: Hey, it looks like I’m finally out of posting detention!
