Can someone tell me how much space I would realistically need to install an Atlas or Walthers turntable and roundhouse?
In HO Atlas----2 1/2 feet x 2 1/2 feet
walthers-about the same
In N Atlas----2 foot x 2 foot
I more sure about the N scale then the HO scale cause I am building a turntable and roundhouse setup from the Walthers model kits.
I would have to say the the 2.5’ x 2.5’ is pretty close. I have just started building the Roundhouse and Turntable from Atlas on a 5’x9’ layout. I’m using two kits to make a six stall structure with a couple spots next to it. It’s a good project. It is kinda tight but I think that it will look and fit quite well.
Good Luck. John
Sure eats up alot of space.I never knew it took that much!
For large steam you’ll need a minimum of a 13" (95’) my 4-8-4 with tender will just fit. Add 6-8" for transition betwen turntable and roundhouse and another 14" for the roundhouse and you’ve got your 2 1/2’. A workable service area with ash pit, coal & water towers, and a sand house covers just shy of 4 1/2’ x 3’. I’ve found mine works best on a dead end peninsula, but I’ve seen some very nice set ups in just under 3’ square. Look at some old photos, they really packed it in tight.
Luck
The more that I look at it the more I can use my imagination. When I get ready to build my big Layout the Turntable and Roundhouse will be in a prominent corner of the Layout. I think, since it takes up alot of square footage, that would be the best spot for it. (either inside or outside corner)
John
Model Railroader has a book called “Locomotive Servicing Terminals” that can give you lots of ideas, but you can also make improvements on their suggestions. A corner installation is a good one too, If you run a track around the back of it, just be sure you can reach it. First Law of Model Railroading - “If you can’t reach it, It will give you problems”
Luck
