I am fascinated by the fact that many North American layouts are built on two levels. Can I be enlightened as to what is the attraction, other than to pack even more into the space available. I have visited one split level HO layout at a club in the UK and found the whole thing very distracting. It was difficult to get an overview and the whole arrangement just seemed over complicated and claustrophobic. I have never seem a similar split level layout based on UK railways. Maybe big is beautiful in North America.
Certainly wanting to pack more layout into the fixed space is one reason for multi-deck layouts (and I recall an article in Model Railroad Planning about an around-the-walls 6 or 7 deck layout that a guy built in the dining room of his house!). Years ago layout planners would double or even triple back against themselves so the trains would run back and forth across the same scene in a very unrealistic manner. If you want a long mainline run (and many of us do), your choices are the old fashioned spaghetti bowl track plan (or as one MR article called it “a pail of snakes”) or multi deck.
But a major reason has more to do with how many layouts in the US are operated versus what I have seen and read about UK layouts. The goal of many layouts in the US is to replicate the complexity of operating opposing trains on a single track railroad, using passing sidings, and controlled using the same timetables and train order operations that the prototype railroads used to use. In order for timetable and train order (“T&TO”) operation to make sense you need fairly extensive runs that take up real time to do, even if you have a fast clock. Unless it is very large, or unless you are content with just a “flavor” of T&TO operation, a single deck layout just doesn’t give you enough of a railroad to have the system make any sense or be any fun. You want both the origination and the destination to be part of the layout in other words, plus everything in between (origination and destination might one or both be staging yards and not truly modeled).
A “mere” scale mile of track (60 feet in HO) while more than ample for a layout which looks at a single locale, say, a compex junction, or an important station, and watches the trains go to and fro, just is not enough to make sense of meets and passes, governed not by signals but by timetables an
I suspect a double-deck layout is a bit like getting your first pair of bifocals - it’s takes a little while to get used to, but once you do, it’s not a problem. Also, from what I understand, viewing a double-deck layout is different than operating on one. Once you are running a train, your mind tends to focus in on that level only; you don’t really notice the other level.
Also, many UK layouts are built to be operated at train shows, rather than as a permanent home layout. Fewer UK folks have access to a large home space like a basement to build a layout in. I would not expect anyone to build a portable double-deck layout, though I suppose it’s technically possible.
I don’t know how many people in the US actually have built double-deck home layouts, but I suspect it’s much lower than the percentage of such layouts featured in the magazines. It seems to me that large, double-deck home layouts designed to be operated by multiple people tend to be the layouts featured in MR and RMC.
Yes, and? There’s a guy not far from me that owns a Ford GT40 and has a friend that owns another. I’ve seen both parked in his driveway. This doesn’t make GT40s common. That pair represents 2 percent of all the GT40s in the world.
Well, there are “two deck” layouts and then there are “two deck layouts”. To clarify, I’ve built two 2 deckers but the lower level was simply for staging. The max clearance was 14-15 inches, and just enough to get to the 6 tracks of staging.
Having two scenicked decks is certainly doable, but I believe I would find it hard to fully enjoy the lower deck due to access (manually & visually) and perhaps difficult to enjoy the upper deck due to its height.
But that is just my take on the subject, and we all are fully entitled to have our own of course.
I had a minimal lower level for my subways, barely a few inches below the main layout. It was basically a loop with a couple of sidings. It ran independently of the tracks above. It was fun to build, but it really couldn’t be “operated.”
I was simply saying that two deck layouts are NOT uncommon in Southern California. I used to operate with the Los Angeles Model Railroad Society until they lost their lease. They have secured a new location and are currently building a two deck layout. Hopefully, I’ll get to operate on that layout soon.
Car shows around here always have huge corrals for Cobra’s, GT40’s, Daytona Coupe’s and other Shelby inspired cars. So just because something is uncommon in your area doesn’t necessarily mean it is equally uncommon somewhere else.
