Recently completed building Atlas Layout 102 (Trunk Line) from the book Atlas HO Beginners Guide, dated 1960, and using a MRC Tech 4 model 280 duel controller.
I have checked AC and DC voltages going to my switches and terminals. All is good.
Resistance checks indicate wiring is good.
I suspect that there may be a flaw in the Layout 102 wiring diagram, or I have missed something in my wiring. In the schematic it shows two individal controllers being used. One dc lead on one controller (lets call it “B”) is going directly to one side of my selector for the terminals. The other controller (call it “A”) has one lead going directly to the other side of my selector switch for the terminals. The unused side of controller A and B are tied together in a terminal block and one lead comes out and is designated common lead which continues to one side of track terminal #7. The other side of track terminal #7 goes back to selector switch #7.
Thinking my consist egines were faulty, tried all three individaully. No go.
Could the leads on track terminal #7 need to be reversed? Currently, the common lead is on the right side of the terminal and the wire going to switch #7 is on the left.
Track terminals 1 - 6 only have one lead, which go to the respective selector switches.
I did find one turnout selector switch that is bad (no AC on the terminals of the switch) which I am replacing. All other turnout selector switches are good.
Any suggestions?
